Large surface with texture variation
Peperepe77
Post by Peperepe77 » Fri Apr 19, 2019 4:06 pm
Hi guys,it is possible with node setup create texture variation? For example, large concrete floor with mix material "concrete 1" and "concrete2" and third texture to mix. What are correct node setup?
Re: Large surface with texture variation
Post by kintuX » Sun Apr 21, 2019 1:12 pm
Peperepe77
Post by Peperepe77 » Sun Apr 21, 2019 2:11 pm
Thank's kintux. I try this node setup (similar to cycles): material A and material B connected on mix material, mix factor connected with blender noise texture.
Post by B.Y.O.B. » Sun Apr 21, 2019 4:34 pm
Blender noise is the old noise texture from Blender Internal, it's very peculiar.
You should use Blender clouds instead, it is the quivalent of Cycles "noise".
