RPly: Unable to open file
motaman
Post by motaman » Fri Apr 05, 2019 10:02 pm
:lol: :cry:
Okay so i'm trying to run luxcorescenedemo.exe , i made sure the ply was ok.
the file was damaged or something so i had to replace suzanne.ply, but the same error showed up
C:\Users\Daniel\Desktop\Luxcorerender\WindowsCompile\Build_CMake\LuxCore\bin\Debug>luxcorescenedemo.exe
LuxCore 2.2alpha1
[SDL][0.000] Camera type: perspective
[SDL][0.000] Camera position: Point[1, 6, 3]
[SDL][0.000] Camera target: Point[0, 0, 0.5]
[SDL][0.000] Camera clipping plane disabled
[SDL][0.031] Define ImageMap: check_texmap
[SDL][0.031] Texture definition: map
[SDL][0.031] Material definition: whitelight
[SDL][0.031] Material definition: mat_white
[SDL][0.031] Material definition: mat_red
[SDL][0.031] Material definition: mat_glass
[SDL][0.047] Material definition: mat_gold
[SDL][0.047] Scene objects count: 1
[SDL][0.047] The box03 object is a light sources with 12 triangles
RUNTIME ERROR: Unable to read PLY mesh file 'samples/luxcorescenedemo/suzanne.ply'
instagram: motaman.art
Fox
Re: RPly: Unable to open file
Post by Fox » Fri Apr 05, 2019 11:16 pm
I don't even know what is luxcorescenedemo.exe :oops:
I only have luxcoreui.exe and pyluxcoretool.exe
This is all i need.
nigec
Post by nigec » Sat Apr 06, 2019 11:29 am
it works using the sdk, did you have
luxcorescenedemo.exe and the various dlls then the folders scenes and samples
motaman
Post by motaman » Sat Apr 06, 2019 3:24 pm
:o :o :o :o :o :o :o :o :o :o :o
Thanks a lot that worked !
btw don't replace the ply like i did , I had to get it back
motaman
Post by motaman » Sat Apr 06, 2019 3:42 pm
:? :D
