The color selection tool has a bug
Dez!
Post by Dez! » Tue Feb 12, 2019 6:13 am
The values in these two windows are different.
Linux Gnome | Dell Inspiron 7000 | Wacom
Re: The color selection tool has a bug
Post by B.Y.O.B. » Tue Feb 12, 2019 8:56 am
Please upload a small testscene that shows the problem.
Dez!
Post by Dez! » Tue Feb 12, 2019 1:43 pm
https://youtu.be/4UXwfm-3WVk
It's happening in any scene.
Post by B.Y.O.B. » Tue Feb 12, 2019 2:11 pm
Not on my system. I need to see your color management settings etc.
Luximage
Post by Luximage » Tue Feb 12, 2019 10:06 pm
It happens to me also.
Dez!
Post by Dez! » Wed Feb 13, 2019 9:59 am
POP! OS (Ubuntu 18.04)
No special color settings. All default settings.
Post by epilectrolytics » Wed Feb 13, 2019 12:12 pm
On my Mac and my PC it works correctly, no difference between node and pop-up values.
I have not changed any settings in Blender color management, should be at default.
MBPro 15" 16GB i7-4850HQ GT750M, MacOS 10.13.6 & Win10Pro PC 16GB Ryzen 2700X, 2 x RTX 2070
acasta69
Post by acasta69 » Wed Feb 13, 2019 1:08 pm
My system shows the problem too.
Default cube scene, switch to Luxcore engine, add Constant color node, increase "brightness" with the vertical bar on the right.
RGB values are always the same in node and color picker, while HSV differ:
One of the two is not consistent, i think it is the one in the node.
When the value in the vertical bar is at about mid-height, RGB values are all near 0.200-0.250, but in HSV we should have V ~ 0.500, correct? It is also near 0.2 instead:
If color picker is chosen from the last picture above, it shows V near 0.5 (compare with the first attached picture).
Windows 10 64 bits, i7-4770 3.4 GHz, RAM 16 GB, GTX 970 4GB v382.05
Post by B.Y.O.B. » Wed Feb 13, 2019 1:11 pm
It has probably something to do with sRGB correction.
In general it is pretty hard to apply meaning to HSV/RGB/Hex values.
But if I can't reproduce it on my end, I can't fix it.
edit: I found a scene where I can reproduce it.
Post by B.Y.O.B. » Thu Feb 14, 2019 10:20 am
I fixed the problem.
