Thanks B.Y.O.B,B.Y.O.B. wrote: Thu May 10, 2018 4:41 pm Please test your script with Cycles as render engine.
If it works ok there but not in BlendLuxCore, I will investigate.
I did as you suggested.
In cycles, the pattern always appears in the render results, on both computers.
(A link to the scene with cycles for JIC: https://drive.google.com/open?id=1WXLrZ ... 7eJmI1iZYJ)
Would you be so kind to check this issue?
Many thanks,
Igal
