[CRASHING] Simples scene crashing on RTX2070
Re: [CRASHING] Simples scene crashing on RTX2070
Try to check the %tmp% directory for a crash log. It has the name "<name-of-blendfile>.crash.txt" and usually contains a stacktrace that might help us.
hilth
Post by hilth »
AndreasResch wrote: Thu Apr 15, 2021 1:19 pm Have you tried starting Blender in debug mode with "blender -d"? Maybe the console window gives some insight into the issue.
I don't even know what that means. hehe
hilth
Post by hilth »
B.Y.O.B. wrote: Thu Apr 15, 2021 2:36 pm Try to check the %tmp% directory for a crash log. It has the name "<name-of-blendfile>.crash.txt" and usually contains a stacktrace that might help us.
This is what the file shows:
# Blender 2.92.0, Commit date: 2021-02-24 16:25, Hash 02948a2cab44
Read library:  'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Arc__Light.blend', 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Arc__Light.blend', parent '<direct>'  # Info
Read library:  'C:\Users\augus\LuxCoreOnlineLibrary_data\model\B-Home_Pack_1.blend', 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\B-Home_Pack_1.blend', parent '<direct>'  # Info
Read library:  'C:\Users\augus\LuxCoreOnlineLibrary_data\model\BB_SOFA_C2.blend', 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\BB_SOFA_C2.blend', parent '<direct>'  # Info
Read library:  'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Golden_Glass_Table.blend', 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Golden_Glass_Table.blend', parent '<direct>'  # Info
Read library:  'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Interior_Plant_1.blend', 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Interior_Plant_1.blend', parent '<direct>'  # Info
Read library:  'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Straight_Curtain.blend', 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Straight_Curtain.blend', parent '<direct>'  # Info
bpy.ops.object.select_all(action='DESELECT')  # Operator
bpy.context.space_data.shading.type = 'SOLID'  # Property
Saved "Luxcore teste live.blend"  # Info
bpy.ops.outliner.select_box(tweak=True, xmin=100, xmax=197, ymin=622, ymax=809)  # Operator
bpy.ops.outliner.item_activate(extend=False, deselect_all=True)  # Operator
bpy.ops.outliner.select_box(tweak=True, xmin=121, xmax=202, ymin=605, ymax=816)  # Operator
bpy.context.space_data.shading.type = 'RENDERED'  # Property
# backtrace
Exception Record:
ExceptionCode         : UNKNOWN EXCEPTION
Exception Address     : 0x00007FFC8559D759
Exception Module      : KERNELBASE.dll
Exception Flags       : 0x00000001
Exception Parameters  : 0x4
	Parameters[0] : 0x0000000019930520
	Parameters[1] : 0x000000D73F7FF4B8
	Parameters[2] : 0x00007FFBE9264E58
	Parameters[3] : 0x00007FFBE85A0000
Stack trace:
KERNELBASE.dll      :0x00007FFC8559D6F0  RaiseException
VCRUNTIME140.dll    :0x00007FFC75596180  CxxThrowException
pyluxcore.pyd       :0x00007FFBE86EC5A0  boost::serialization::void_cast_register<slg::MistPlugin,slg::ImagePipelinePlugin>
pyluxcore.pyd       :0x00007FFBE8908250  PyInit_pyluxcore
pyluxcore.pyd       :0x00007FFBE8719170  boost::archive::detail::pointer_oserializer<boost::archive::binary_oarchive,luxrays::SpectrumGroup>
ucrtbase.dll        :0x00007FFC85491B20  configthreadlocale
KERNEL32.DLL        :0x00007FFC86E57020  BaseThreadInitThunk
ntdll.dll           :0x00007FFC879E2630  RtlUserThreadStart
Threads:
Thread : 00004300
ntdll.dll           :0x00007FFC87A2D750  NtWaitForMultipleObjects
KERNELBASE.dll      :0x00007FFC855C0C50  WaitForMultipleObjectsEx
pyluxcore.pyd       :0x00007FFBE8653CF0  boost::serialization::singleton<boost::archive::detail::extra_detail::guid_initializer<slg::RenderS
pyluxcore.pyd       :0x00007FFBE85B7CA0  boost::serialization::singleton_module::is_locked
pyluxcore.pyd       :0x00007FFBE88D8F20  boost::serialization::singleton<boost::archive::detail::extra_detail::map<boost::archive::binary_oa
python37.dll        :0x00007FFBF7B9E3F0  PyType_GenericNew
python37.dll        :0x00007FFBF7B66190  PyFrame_GetLineNumber
python37.dll        :0x00007FFBF7C7A1B0  PyThread_GetInfo
python37.dll        :0x00007FFBF7C0E490  PyEval_EvalFrameDefault
python37.dll        :0x00007FFBF7B464E0  PyObject_Call
blender.exe         :0x00007FF7056E4C40  bpy_class_call
blender.exe         :0x00007FF7056CC660  engine_view_draw
blender.exe         :0x00007FF70539DBB0  external_draw_scene
blender.exe         :0x00007FF705366AD0  drw_engines_draw_scene
blender.exe         :0x00007FF705363460  DRW_draw_render_loop_ex
blender.exe         :0x00007FF7053644C0  DRW_draw_view
blender.exe         :0x00007FF705B32770  view3d_main_region_draw
blender.exe         :0x00007FF70570BC20  ED_region_do_draw
blender.exe         :0x00007FF7052ABBF0  wm_draw_window_offscreen
blender.exe         :0x00007FF7052ABA40  wm_draw_window
blender.exe         :0x00007FF7052AB540  wm_draw_update
blender.exe         :0x00007FF7052884D0  WM_main
blender.exe         :0x00007FF704F79C70  main
blender.exe         :0x00007FF709483468  __scrt_common_main_seh
Thread : 0000199c
ntdll.dll           :0x00007FFC87A2CC80  ZwWaitForSingleObject
KERNELBASE.dll      :0x00007FFC8558A2C0  WaitForSingleObjectEx
blender.exe         :0x00007FF708A801D0  IlmThread_2_4::Semaphore::wait
blender.exe         :0x00007FF708A7F9A0  IlmThread_2_4::ThreadPool::numThreads
blender.exe         :0x00007FF708A80650  std::_LaunchPad<std::unique_ptr<std::tuple<void (__cdecl IlmThread_2_4::Thread::*)(void) __ptr64,Il
blender.exe         :0x00007FF707C759C0  std::_Pad::_Call_func
Thread : 00002b84
Thread : 00003774
Thread : 00003ca0
Thread : 0000517c
Thread : 00003e6c
Thread : 00001370
Thread : 00003e38
Thread : 0000272c
ntdll.dll           :0x00007FFC87A305F0  ZwWaitForAlertByThreadId
ntdll.dll           :0x00007FFC879F3EF0  RtlSleepConditionVariableSRW
KERNELBASE.dll      :0x00007FFC855DBA60  SleepConditionVariableSRW
MSVCP140.dll        :0x00007FFC61AEBA70  _crtSetThreadpoolWait
MSVCP140.dll        :0x00007FFC61AC2650  std::_Winerror_message
OpenAL32.dll        :0x00007FFC003E5670  alcGetInteger64vSOFT
OpenAL32.dll        :0x00007FFC003D0080  alGetError
Thread : 000005e0
Thread : 00004a0c
Thread : 000042e4
combase.dll         :0x00007FFC85F8A880  RoGetServerActivatableClasses
Thread : 00004ba8
ntdll.dll           :0x00007FFC87A30650  NtWaitForWorkViaWorkerFactory
ntdll.dll           :0x00007FFC879E2680  TpReleaseCleanupGroupMembers
Thread : 000049f4
Thread : 0000112c
nvoglv64.dll        :0x00007FFBEA17F9B0  DrvValidateVersion
nvoglv64.dll        :0x00007FFBE9F0CC3D  Symbols not available
Thread : 00004858
KERNELBASE.dll      :0x00007FFC855C0C30  WaitForMultipleObjects
nvoglv64.dll        :0x00007FFBEA1B8D50  DrvPresentBuffers
nvoglv64.dll        :0x00007FFBEA5D2C90  vk_icdNegotiateLoaderICDInterfaceVersion
Thread : 0000374c
win32u.dll          :0x00007FFC850DA0F0  NtUserMsgWaitForMultipleObjectsEx
USER32.dll          :0x00007FFC875A06F0  MsgWaitForMultipleObjectsEx
Thread : 00004bb8
Wacom_Tablet.dll    :0x00007FFC56A58FE9  WTOpenW
Thread : 00002910
tbb.dll             :0x00007FFC6C2319C0  tbb::thread_bound_filter::try_process_item
Thread : 0000303c
Thread : 00004484
Thread : 00004b18
Thread : 00004bd8
Thread : 00004f24
Thread : 00004d68
mswsock.dll         :0x00007FFC848C80FC  Symbols not available
Thread : 00002054
ntdll.dll           :0x00007FFC87A2D280  NtDelayExecution
KERNELBASE.dll      :0x00007FFC855BD7B0  SleepEx
python37.dll        :0x00007FFBF7AF8B60  PyTraceMalloc_GetTraceback
python37.dll        :0x00007FFBF7B46EE0  PyMethodDef_RawFastCallKeywords
python37.dll        :0x00007FFBF7C13FA0  PyEval_GetFuncDesc
python37.dll        :0x00007FFBF7B469C0  PyFunction_FastCallKeywords
python37.dll        :0x00007FFBF7B47730  PyObject_Call_Prepend
python37.dll        :0x00007FFBF7AF2BA0  PyOS_SigintEvent
python37.dll        :0x00007FFBF7C79690  PyThread_init_thread
Thread : 00001920
Thread : 00003200
Thread : 00003b1c
VCOMP140.DLL        :0x00007FFC067A2554  vcomp_ordered_loop_end
VCOMP140.DLL        :0x00007FFC067A7FB0  vcomp_atomic_div_r8
Thread : 00003a14
Thread : 00002ad4
Thread : 00000508
Thread : 00001de8
Thread : 00002eb0
Thread : 00001b34
Thread : 0000155c
nvcuda64.dll        :0x00007FFC62DD6714  Symbols not available
Thread : 00002868
nvcuda64.dll        :0x00007FFC62E40D80  cuProfilerStop
nvcuda64.dll        :0x00007FFC62DD60E3  Symbols not available
Thread : 00004008
ntdll.dll           :0x00007FFC879F4190  RtlSleepConditionVariableCS
KERNELBASE.dll      :0x00007FFC855DB9B0  SleepConditionVariableCS
nvcuda64.dll        :0x00007FFC62D54A9C  Symbols not available
Thread : 000013d4
Thread : 00004bac
Thread : 000047f4
Thread : 0000460c
Thread : 000046d8
Thread : 000045bc
Thread : 00001b7c
Thread : 00004c3c
Thread : 0000349c
Thread : 00002ed0
Loaded Modules :
0x00007FF704E50000 2.9.2.0              blender.exe C:\Program Files\Blender Foundation\Blender 2.92\blender.pdb
0x00007FFC87990000 10.0.19041.844       ntdll.dll
0x00007FFC86E40000 10.0.19041.804       KERNEL32.DLL
0x00007FFC85570000 10.0.19041.804       KERNELBASE.dll
0x00007FFC87580000 10.0.19041.746       USER32.dll
0x00007FFC850D0000 10.0.19041.867       win32u.dll
0x00007FFC6C220000 2019.9.0.0           tbb.dll
0x00007FFC86510000 10.0.19041.746       GDI32.dll
0x00007FFC85360000 10.0.19041.746       gdi32full.dll
0x00007FFC85950000 10.0.19041.789       msvcp_win.dll
0x00007FFC85470000 10.0.19041.789       ucrtbase.dll
0x00007FFC866F0000 10.0.19041.844       SHELL32.dll
0x00007FFC75590000 14.26.28720.3        VCRUNTIME140.dll
0x00007FFC61AB0000 14.26.28720.3        MSVCP140.dll
0x00007FFC85260000 10.0.19041.546       CFGMGR32.dll
0x00007FFC877D0000 10.0.19041.546       WS2_32.dll
0x00007FFC86360000 10.0.19041.746       RPCRT4.dll
0x00007FFC61980000 10.0.19041.844       OPENGL32.dll
0x00007FFC00510000 7.0.0.0              openvdb.dll
0x00007FFC85D30000 7.0.19041.546        msvcrt.dll
0x00007FFC878A0000 10.0.19041.610       ADVAPI32.dll
0x00007FFC85EC0000 10.0.19041.844       combase.dll
0x00007FFC85B40000 10.0.19041.789       sechost.dll
0x00007FFC87450000 10.0.19041.746       ole32.dll
0x00007FFC85DD0000 10.0.19041.546       PSAPI.DLL
0x00007FFBF7700000 58.29.100.0          avformat-58.dll
0x00007FFC85CB0000 10.0.19041.746       SHLWAPI.dll
0x00007FFBEBEA0000 58.54.100.0          avcodec-58.dll
0x00007FFC85B10000 10.0.19041.546       IMM32.dll
0x00007FFC61950000 58.8.100.0           avdevice-58.dll
0x00007FFC54820000 56.31.100.0          avutil-56.dll
0x00007FFC85BE0000 10.0.19041.804       OLEAUT32.dll
0x00007FFC852B0000 10.0.19041.662       bcrypt.dll
0x00007FFC41170000 5.5.100.0            swscale-5.dll
0x0000000070440000 1.0.28.0             libsndfile-1.dll
0x00007FFC003C0000 1.20.1.0             OpenAL32.dll
0x00007FFC2A2D0000 2.0.12.0             SDL2.dll
0x000000006ACC0000                      libgmp-10.dll
0x00007FFC802C0000 2019.9.0.0           tbbmalloc_proxy.dll
0x00007FFC86F00000 10.0.19041.844       SETUPAPI.dll
0x00007FFC7DC60000 14.26.28720.3        VCRUNTIME140_1.dll
0x00007FFBF7A40000 3.7.7150.1013        python37.dll
0x00007FFC673A0000 6.10.19041.844       COMCTL32.dll
0x00007FFC61680000 10.0.19041.1         AVIFIL32.dll
0x00007FFC7E340000 10.0.19041.546       VERSION.dll
0x00007FFC837F0000 10.0.19041.867       dbghelp.dll
0x00007FFC60950000 10.0.19041.844       GLU32.dll
0x00007FFC69460000 10.0.19041.546       Secur32.dll
0x00007FFC5C810000 3.5.100.0            swresample-3.dll
0x0000000070680000                      libfftw3-3.dll
0x00007FFC58A80000 10.0.19041.1         AVICAP32.dll
0x00007FFC5C7D0000 2019.9.0.0           tbbmalloc.dll
0x00007FFC3D030000 10.0.19041.1         MSVFW32.dll
0x00007FFC6FE80000 10.0.19041.546       WINMM.dll
0x00007FFC5FCE0000 10.0.19041.1         MSACM32.dll
0x00007FFC84F90000 10.0.19041.662       SSPICLI.DLL
0x00007FFC66650000 10.0.19041.1         winmmbase.dll
0x00007FFC862B0000 10.0.19041.746       shcore.dll
0x00007FFC83A00000 10.0.19041.546       kernel.appcore.dll
0x00007FFC82F60000 10.0.19041.844       windows.storage.dll
0x00007FFC84B40000 10.0.19041.662       Wldp.dll
0x00007FFC828C0000 10.0.19041.746       uxtheme.dll
0x00007FFC852E0000 10.0.19041.662       bcryptPrimitives.dll
0x00007FFC85010000 10.0.19041.844       profapi.dll
0x00007FFC87720000 2001.12.10941.16384  clbcatq.dll
0x00007FFC7F720000 10.0.19041.789       MMDevApi.dll
0x00007FFC84E80000 10.0.19041.546       DEVOBJ.dll
0x00007FFC7FB40000 10.0.19041.789       AUDIOSES.DLL
0x00007FFC846D0000 10.0.19041.546       powrprof.dll
0x00007FFC84540000                      UMPDC.dll
0x00007FFC82980000 10.0.19041.546       resourcepolicyclient.dll
0x00007FFC859F0000 10.0.19041.867       MSCTF.dll
0x00007FFC6A3F0000 10.0.19041.746       dataexchange.dll
0x00007FFC80BE0000 10.0.19041.746       d3d11.dll
0x00007FFC81B50000 10.0.19041.746       dcomp.dll
0x00007FFC83A20000 10.0.19041.746       dxgi.dll
0x00007FFC7E110000 10.0.19041.746       twinapi.appcore.dll
0x00007FFC7D530000 10.0.19041.844       AppXDeploymentClient.dll
0x00007FFBE9510000 27.21.14.6140        nvoglv64.dll
0x00007FFC80BC0000 10.0.19041.546       WTSAPI32.dll
0x00007FFC84CC0000 10.0.19041.546       msasn1.dll
0x00007FFC7DCB0000 10.0.19041.546       cryptnet.dll
0x00007FFC85100000 10.0.19041.844       CRYPT32.dll
0x00007FFC84AB0000 10.0.19041.546       cryptbase.dll
0x00007FFC85840000 10.0.19041.804       WINTRUST.dll
0x00007FFC83E20000 10.0.19041.546       ntmarta.dll
0x00007FFC78750000 10.0.19041.546       dxcore.dll
0x00007FFC82C70000 10.0.19041.746       dwmapi.dll
0x00007FFC843D0000 10.0.19041.546       WINSTA.dll
0x00007FFC7B6C0000 10.0.19041.844       textinputframework.dll
0x00007FFC824B0000 10.0.19041.746       CoreMessaging.dll
0x00007FFC82100000 10.0.19041.546       CoreUIComponents.dll
0x00007FFC819F0000 10.0.19041.844       wintypes.dll
0x00007FFBF1040000 1.0.5.10             Wintab32.dll
0x00007FFC760E0000 10.0.19041.546       MPR.dll
0x00007FFC56A50000 6.3.42.2             Wacom_Tablet.dll
0x00007FFC5EDC0000 10.0.19041.844       explorerframe.dll
0x00007FFC80910000 7.0.19041.867        propsys.dll
0x00007FFC84A90000 10.0.19041.546       CRYPTSP.dll
0x00007FFC84190000 10.0.19041.546       rsaenh.dll
0x00007FFC7B7C0000 3.7.7150.1013        python3.dll
0x00007FFBF0D70000                      _multiarray_umath.cp37-win_amd64.pyd
0x00007FFC69C80000                      _multiarray_tests.cp37-win_amd64.pyd
0x00007FFC5AA80000 3.7.7150.1013        _ctypes.pyd
0x00007FFC410E0000                      lapack_lite.cp37-win_amd64.pyd
0x00007FFBF0B50000                      _umath_linalg.cp37-win_amd64.pyd
0x00007FFC69510000 3.7.7150.1013        _bz2.pyd
0x00007FFC56A10000 3.7.7150.1013        _lzma.pyd
0x00007FFC52C90000 3.7.7150.1013        _decimal.pyd
0x00007FFC66E00000                      _pocketfft_internal.cp37-win_amd64.pyd
0x00007FFC2BAF0000                      mtrand.cp37-win_amd64.pyd
0x00007FFC5A910000                      common.cp37-win_amd64.pyd
0x00007FFC2BAA0000                      bounded_integers.cp37-win_amd64.pyd
0x00007FFC64290000                      mt19937.cp37-win_amd64.pyd
0x00007FFC3AAD0000                      bit_generator.cp37-win_amd64.pyd
0x00007FFC79600000 3.7.7150.1013        _hashlib.pyd
0x00007FFBF0800000 1.1.1.4              libcrypto-1_1.dll
0x00007FFC60930000                      philox.cp37-win_amd64.pyd
0x00007FFC5D2E0000                      pcg64.cp37-win_amd64.pyd
0x00007FFC5AA60000                      sfc64.cp37-win_amd64.pyd
0x00007FFC00320000                      generator.cp37-win_amd64.pyd
0x00007FFBF0400000                      etree.cp37-win_amd64.pyd
0x00007FFC29B50000                      _elementpath.cp37-win_amd64.pyd
0x00007FFC59D80000 3.7.7150.1013        _socket.pyd
0x00007FFC78100000 3.7.7150.1013        select.pyd
0x00007FFC530A0000 3.7.7150.1013        _ssl.pyd
0x00007FFC00270000 1.1.1.4              libssl-1_1.dll
0x00007FFC768D0000 3.7.7150.1013        _queue.pyd
0x00007FFC848C0000 10.0.19041.546       mswsock.dll
0x00007FFBF02F0000 3.7.7150.1013        unicodedata.pyd
0x00007FFC05970000                      sketchup.cp37-win_amd64.pyd
0x00007FFBEE620000 20.1.229.0           SketchUpAPI.dll
0x00007FFBF0270000 20.1.229.63          SketchUpCommonPreferences.dll
0x00007FFC845A0000 10.0.19041.746       DNSAPI.dll
0x00007FFC84560000 10.0.19041.546       IPHLPAPI.DLL
0x00007FFC86490000 10.0.19041.610       NSI.dll
0x00007FFC7B8D0000 10.0.19041.844       fwpuclnt.dll
0x00007FFC7AEA0000 10.0.19041.546       rasadhlp.dll
0x00007FFBE85A0000                      pyluxcore.pyd
0x00007FFC067A0000 14.26.28720.3        VCOMP140.DLL
0x00007FFBE2D80000                      OpenImageIO_LuxCore.dll
0x00007FFBE39F0000 1.2.1.0              OpenImageDenoise.dll
0x00007FFBE64B0000 3.8.0.0              embree3.dll
0x00007FFBF0100000 2.2.8.0              OpenCL.dll
0x00007FFC76970000 27.21.14.6140        nvcuda.dll
0x00007FFC62C20000 27.21.14.6140        nvcuda64.dll
0x00007FFBE1DF0000 6.14.11.9000         nvrtc64_101_0.dll
0x00007FFC6CE90000 27.21.14.6140        nvapi64.dll
0x00007FFBD8680000 7.3.0.0              nvoptix.dll
0x00007FFBD7480000 27.21.14.6140        nvopencl64.dll
0x00007FFC7C050000 10.0.19041.844       drvstore.dll
0x00007FFBD38D0000 27.21.14.6140        nvrtum64.dll
0x00007FFBF0060000 8.17.14.6140         nvml.dll
0x00007FFBEDEC0000 8.17.14.6140         nvml.dll
0x00007FFBD30B0000 27.21.14.6140        nvptxJitCompiler64.dll
# Python backtrace
Are you try to periodically save the film or something similar ? You seem to try to serialize a Film but it can happen only if you have enabled some kind of periodic saving. It is very strange.
AndreasResch
Post by AndreasResch »
hilth wrote: Thu Apr 15, 2021 2:40 pm
If you know how to start programs from the command line in windows, you can go to the directory where the "blender.exe" file is and type "blender -d" and hit ENTER. But if you are not familiar with starting programs from the command line, it will be too complicated.
hilth
Post by hilth »
Dade wrote: Thu Apr 15, 2021 4:11 pm Are you try to periodically save the film or something similar ? You seem to try to serialize a Film but it can happen only if you have enabled some kind of periodic saving. It is very strange.
Not sure what you mean.
I didn't try anything fence. I just tried to render the scene using the viewport GPU mode.
(I updated my gpu driver last night and remade this tests)
In fact, I'm more like a general user, so I'm not familiar with code or these complicated things.
I also tried to render the scene properly by hitting F12, and it also didn't work. Blender just freezes and after a minute it crashed.
I'll try t clean the temp folder and turn of some addons to see if will work.
here is the log:
# backtrace
Exception Record:
Exception Address     : 0x00007FF83EB8D759
	Parameters[1] : 0x0000003E829FF3A8
	Parameters[2] : 0x00007FFFB3924E58
	Parameters[3] : 0x00007FFFB2C60000
Stack trace:
KERNELBASE.dll      :0x00007FF83EB8D6F0  RaiseException
VCRUNTIME140.dll    :0x00007FF82D636180  CxxThrowException
pyluxcore.pyd       :0x00007FFFB2DAC5A0  boost::serialization::void_cast_register<slg::MistPlugin,slg::ImagePipelinePlugin>
pyluxcore.pyd       :0x00007FFFB2FC8250  PyInit_pyluxcore
pyluxcore.pyd       :0x00007FFFB2DD9170  boost::archive::detail::pointer_oserializer<boost::archive::binary_oarchive,luxrays::SpectrumGroup>
ucrtbase.dll        :0x00007FF83E881B20  configthreadlocale
KERNEL32.DLL        :0x00007FF8403C7020  BaseThreadInitThunk
ntdll.dll           :0x00007FF840F82630  RtlUserThreadStart
Threads:
Thread : 00004d4c
ntdll.dll           :0x00007FF840FCCC80  ZwWaitForSingleObject
KERNELBASE.dll      :0x00007FF83EB7A2C0  WaitForSingleObjectEx
python37.dll        :0x00007FFFBA29D500  Py_HashRandomization_Fini
python37.dll        :0x00007FFFBA29DFB0  PyEval_RestoreThread
python37.dll        :0x00007FFFBA2E06D0  PyGILState_Ensure
blender.exe         :0x00007FF7C6AFB560  bpy_context_set
blender.exe         :0x00007FF7C6B04C40  bpy_class_call
blender.exe         :0x00007FF7C6A8B830  header_draw
blender.exe         :0x00007FF7C6B2C9A0  ED_region_header_layout
blender.exe         :0x00007FF7C6B2C0C0  ED_region_do_layout
blender.exe         :0x00007FF7C66CBBF0  wm_draw_window_offscreen
blender.exe         :0x00007FF7C66CBA40  wm_draw_window
blender.exe         :0x00007FF7C66CB540  wm_draw_update
blender.exe         :0x00007FF7C66A84D0  WM_main
blender.exe         :0x00007FF7C6399C70  main
blender.exe         :0x00007FF7CA8A3468  __scrt_common_main_seh
Thread : 00000bb4
blender.exe         :0x00007FF7C9EA01D0  IlmThread_2_4::Semaphore::wait
blender.exe         :0x00007FF7C9E9F9A0  IlmThread_2_4::ThreadPool::numThreads
blender.exe         :0x00007FF7C9EA0650  std::_LaunchPad<std::unique_ptr<std::tuple<void (__cdecl IlmThread_2_4::Thread::*)(void) __ptr64,Il
blender.exe         :0x00007FF7C90959C0  std::_Pad::_Call_func
Thread : 0000061c
Thread : 00002628
Thread : 00003b68
Thread : 000043fc
Thread : 00004b64
Thread : 00004474
Thread : 00002a44
Thread : 00004864
ntdll.dll           :0x00007FF840FD05F0  ZwWaitForAlertByThreadId
ntdll.dll           :0x00007FF840F93EF0  RtlSleepConditionVariableSRW
KERNELBASE.dll      :0x00007FF83EBCBA60  SleepConditionVariableSRW
MSVCP140.dll        :0x00007FF82A5BBA70  _crtSetThreadpoolWait
MSVCP140.dll        :0x00007FF82A592650  std::_Winerror_message
OpenAL32.dll        :0x00007FFFCB5A5670  alcGetInteger64vSOFT
OpenAL32.dll        :0x00007FFFCB590080  alGetError
Thread : 000010f4
Thread : 00000c80
Thread : 00000808
ntdll.dll           :0x00007FF840FD0650  NtWaitForWorkViaWorkerFactory
ntdll.dll           :0x00007FF840F82680  TpReleaseCleanupGroupMembers
Thread : 00004d24
nvoglv64.dll        :0x00007FFFB5D60310  DrvValidateVersion
nvoglv64.dll        :0x00007FFFB5AED59D  Symbols not available
Thread : 00000c70
ntdll.dll           :0x00007FF840FCD750  NtWaitForMultipleObjects
KERNELBASE.dll      :0x00007FF83EBB0C50  WaitForMultipleObjectsEx
KERNELBASE.dll      :0x00007FF83EBB0C30  WaitForMultipleObjects
nvoglv64.dll        :0x00007FFFB5D996B0  DrvPresentBuffers
nvoglv64.dll        :0x00007FFFB61B5920  vk_icdNegotiateLoaderICDInterfaceVersion
Thread : 00002cd4
win32u.dll          :0x00007FF83E78A0F0  NtUserMsgWaitForMultipleObjectsEx
USER32.dll          :0x00007FF8401706F0  MsgWaitForMultipleObjectsEx
Thread : 00002e8c
Wacom_Tablet.dll    :0x00007FF810CE8FE9  WTOpenW
Thread : 000003a4
tbb.dll             :0x00007FF82D7E19C0  tbb::thread_bound_filter::try_process_item
Thread : 00002064
Thread : 000045f0
Thread : 00000430
Thread : 00003730
mswsock.dll         :0x00007FF83DE680FC  Symbols not available
Thread : 00004624
ntdll.dll           :0x00007FF840FCD280  NtDelayExecution
KERNELBASE.dll      :0x00007FF83EBAD7B0  SleepEx
python37.dll        :0x00007FFFBA188B60  PyTraceMalloc_GetTraceback
python37.dll        :0x00007FFFBA1D6EE0  PyMethodDef_RawFastCallKeywords
python37.dll        :0x00007FFFBA2A3FA0  PyEval_GetFuncDesc
python37.dll        :0x00007FFFBA29E490  PyEval_EvalFrameDefault
python37.dll        :0x00007FFFBA1D64E0  PyObject_Call
python37.dll        :0x00007FFFBA1D69C0  PyFunction_FastCallKeywords
python37.dll        :0x00007FFFBA1D7730  PyObject_Call_Prepend
python37.dll        :0x00007FFFBA182BA0  PyOS_SigintEvent
python37.dll        :0x00007FFFBA309690  PyThread_init_thread
Thread : 00002db8
Thread : 000037e8
Thread : 00003fdc
Thread : 000049cc
Thread : 00004780
pyluxcore.pyd       :0x00007FFFB2D8F540  boost::archive::detail::oserializer<boost::archive::binary_oarchive,slg::ImagePipeline>::save_objec
pyluxcore.pyd       :0x00007FFFB2C77CA0  boost::serialization::singleton_module::is_locked
pyluxcore.pyd       :0x00007FFFB2F98F20  boost::serialization::singleton<boost::archive::detail::extra_detail::map<boost::archive::binary_oa
python37.dll        :0x00007FFFBA1D62F0  PyObject_FastCallKeywords
blender.exe         :0x00007FF7C6AEC3F0  engine_render
blender.exe         :0x00007FF7C9E2BBD0  engine_render_view_layer
blender.exe         :0x00007FF7C9E2B2E0  RE_engine_render
blender.exe         :0x00007FF7C9E33FE0  do_render
blender.exe         :0x00007FF7C9E34200  do_render_composite
blender.exe         :0x00007FF7C9E34050  do_render_all_options
blender.exe         :0x00007FF7C9E318B0  RE_RenderFrame
blender.exe         :0x00007FF7C73D1B80  render_startjob
blender.exe         :0x00007FF7C66CD7D0  do_job_thread
blender.exe         :0x00007FF7CA8DF320  _ptw32_threadStart
Thread : 000019d8
VCOMP140.DLL        :0x00007FF812BA2554  vcomp_ordered_loop_end
VCOMP140.DLL        :0x00007FF812BA7FB0  vcomp_atomic_div_r8
Thread : 00001d38
Thread : 000047fc
Thread : 00001ce4
Thread : 0000473c
Thread : 00003570
Thread : 0000161c
Thread : 000030b0
nvcuda64.dll        :0x00007FF813B968E4  Symbols not available
Thread : 00004e4c
nvcuda64.dll        :0x00007FF813C01090  cuProfilerStop
nvcuda64.dll        :0x00007FF813B962B3  Symbols not available
Thread : 00003a9c
ntdll.dll           :0x00007FF840F94190  RtlSleepConditionVariableCS
KERNELBASE.dll      :0x00007FF83EBCB9B0  SleepConditionVariableCS
nvcuda64.dll        :0x00007FF813B14D1C  Symbols not available
Thread : 00003ccc
VCRUNTIME140.dll    :0x00007FF82D635560  _CxxUnregisterExceptionObject
Thread : 000022c0
Thread : 00002df8
Thread : 00001204
                    :0x000001746213EC20  Symbols not available
Thread : 00002ac0
Thread : 00001f28
Thread : 00000780
Thread : 00004470
pyluxcore.pyd       :0x00007FFFB2DBA410  boost::archive::detail::pointer_oserializer<boost::archive::binary_oarchive,slg::RadianceChannelSca
                    :0x3FC2F0FD3FC2F0FD  Symbols not available
Loaded Modules :
0x00007FF7C6270000 2.9.2.0              blender.exe C:\Program Files\Blender Foundation\Blender 2.92\blender.pdb
0x00007FF840F30000 10.0.19041.844       ntdll.dll
0x00007FF8403B0000 10.0.19041.804       KERNEL32.DLL
0x00007FF83EB60000 10.0.19041.804       KERNELBASE.dll
0x00007FF840150000 10.0.19041.746       USER32.dll
0x00007FF83E780000 10.0.19041.867       win32u.dll
0x00007FF83FD10000 10.0.19041.746       GDI32.dll
0x00007FF83EA50000 10.0.19041.746       gdi32full.dll
0x00007FF83E960000 10.0.19041.789       msvcp_win.dll
0x00007FF83E860000 10.0.19041.789       ucrtbase.dll
0x00007FF82D7D0000 2019.9.0.0           tbb.dll
0x00007FF83EF90000 10.0.19041.844       SHELL32.dll
0x00007FF83EA00000 10.0.19041.546       CFGMGR32.dll
0x00007FF840470000 10.0.19041.546       WS2_32.dll
0x00007FFFBA550000 7.0.0.0              openvdb.dll
0x00007FF840020000 10.0.19041.746       RPCRT4.dll
0x00007FF829AC0000 10.0.19041.844       OPENGL32.dll
0x00007FFFBA0D0000 3.7.7150.1013        python37.dll
0x00007FF840AA0000 7.0.19041.546        msvcrt.dll
0x00007FF840300000 10.0.19041.610       ADVAPI32.dll
0x00007FF83F7C0000 10.0.19041.844       combase.dll
0x00007FF83FE30000 10.0.19041.789       sechost.dll
0x00007FF8404E0000 10.0.19041.746       SHLWAPI.dll
0x00007FF83FB20000 10.0.19041.746       ole32.dll
0x00007FF83FD70000 10.0.19041.546       PSAPI.DLL
0x00007FF83FD40000 10.0.19041.546       IMM32.dll
0x00007FFFB7A90000 58.29.100.0          avformat-58.dll
0x00007FF82D7A0000 58.8.100.0           avdevice-58.dll
0x00007FF83F6E0000 10.0.19041.804       OLEAUT32.dll
0x00007FFFB7DD0000 58.54.100.0          avcodec-58.dll
0x00007FFFF5DA0000 56.31.100.0          avutil-56.dll
0x00007FF82D4C0000 5.5.100.0            swscale-5.dll
0x00007FF83E750000 10.0.19041.662       bcrypt.dll
0x00007FFFCB580000 1.20.1.0             OpenAL32.dll
0x00007FFFCE4B0000 2.0.12.0             SDL2.dll
0x00007FF839910000 2019.9.0.0           tbbmalloc_proxy.dll
0x00007FF8405D0000 10.0.19041.844       SETUPAPI.dll
0x00007FF82A580000 14.26.28720.3        MSVCP140.dll
0x00007FF82D630000 14.26.28720.3        VCRUNTIME140.dll
0x00007FF8365C0000 14.26.28720.3        VCRUNTIME140_1.dll
0x00007FF82D600000 10.0.19041.1         AVIFIL32.dll
0x00007FF820FA0000 6.10.19041.844       COMCTL32.dll
0x00007FF836F20000 10.0.19041.546       VERSION.dll
0x00007FF82AAA0000 10.0.19041.844       GLU32.dll
0x00007FF83CD60000 10.0.19041.867       dbghelp.dll
0x00007FF82ED30000 10.0.19041.546       Secur32.dll
0x00007FF82A550000 3.5.100.0            swresample-3.dll
0x00007FF82D5E0000 10.0.19041.1         AVICAP32.dll
0x00007FF82C690000 10.0.19041.546       WINMM.dll
0x00007FF82A0D0000 2019.9.0.0           tbbmalloc.dll
0x00007FF82A0A0000 10.0.19041.1         MSVFW32.dll
0x00007FF834E30000 10.0.19041.1         MSACM32.dll
0x00007FF81F0C0000 10.0.19041.1         winmmbase.dll
0x00007FF83E530000 10.0.19041.662       SSPICLI.DLL
0x00007FF83FF70000 10.0.19041.746       shcore.dll
0x00007FF83CFA0000 10.0.19041.546       kernel.appcore.dll
0x00007FF83C500000 10.0.19041.844       windows.storage.dll
0x00007FF83E0E0000 10.0.19041.662       Wldp.dll
0x00007FF83BE60000 10.0.19041.746       uxtheme.dll
0x00007FF83E670000 10.0.19041.662       bcryptPrimitives.dll
0x00007FF83E5B0000 10.0.19041.844       profapi.dll
0x00007FF83FD80000 2001.12.10941.16384  clbcatq.dll
0x00007FF8387C0000 10.0.19041.789       MMDevApi.dll
0x00007FF83E420000 10.0.19041.546       DEVOBJ.dll
0x00007FF838B30000 10.0.19041.789       AUDIOSES.DLL
0x00007FF83DE10000 10.0.19041.546       powrprof.dll
0x00007FF83DD40000                      UMPDC.dll
0x00007FF83BF20000 10.0.19041.546       resourcepolicyclient.dll
0x00007FF840C20000 10.0.19041.867       MSCTF.dll
0x00007FF81E780000 10.0.19041.746       dataexchange.dll
0x00007FF83ABA0000 10.0.19041.746       d3d11.dll
0x00007FF83B0F0000 10.0.19041.746       dcomp.dll
0x00007FF83CFC0000 10.0.19041.746       dxgi.dll
0x00007FF837000000 10.0.19041.746       twinapi.appcore.dll
0x00007FF838650000 10.0.19041.844       AppXDeploymentClient.dll
0x00007FFFB50F0000 27.21.14.6231        nvoglv64.dll
0x00007FF83A160000 10.0.19041.546       WTSAPI32.dll
0x00007FF83E260000 10.0.19041.546       msasn1.dll
0x00007FF836E70000 10.0.19041.546       cryptnet.dll
0x00007FF83EE30000 10.0.19041.844       CRYPT32.dll
0x00007FF83E050000 10.0.19041.546       cryptbase.dll
0x00007FF83E6F0000 10.0.19041.804       WINTRUST.dll
0x00007FF83D3C0000 10.0.19041.546       ntmarta.dll
0x00007FF82CC00000 10.0.19041.546       dxcore.dll
0x00007FF83C140000 10.0.19041.746       dwmapi.dll
0x00007FF83DA80000 10.0.19041.546       WINSTA.dll
0x00007FF82F140000 10.0.19041.844       textinputframework.dll
0x00007FF83B6A0000 10.0.19041.546       CoreUIComponents.dll
0x00007FF83BB50000 10.0.19041.746       CoreMessaging.dll
0x00007FF83AF90000 10.0.19041.844       wintypes.dll
0x00007FFFB9E80000 1.0.5.10             Wintab32.dll
0x00007FF82F980000 10.0.19041.546       MPR.dll
0x00007FF810CE0000 6.3.42.2             Wacom_Tablet.dll
0x00007FF819EB0000 10.0.19041.844       explorerframe.dll
0x00007FF839D70000 7.0.19041.867        propsys.dll
0x00007FF83E030000 10.0.19041.546       CRYPTSP.dll
0x00007FF83D730000 10.0.19041.546       rsaenh.dll
0x00007FF836530000 3.7.7150.1013        python3.dll
0x00007FFFB4E20000                      _multiarray_umath.cp37-win_amd64.pyd
0x00007FF82D4A0000                      _multiarray_tests.cp37-win_amd64.pyd
0x00007FF829550000 3.7.7150.1013        _ctypes.pyd
0x00007FF81A210000                      lapack_lite.cp37-win_amd64.pyd
0x00007FFFB4C00000                      _umath_linalg.cp37-win_amd64.pyd
0x00007FF82AA80000 3.7.7150.1013        _bz2.pyd
0x00007FF81ED20000 3.7.7150.1013        _lzma.pyd
0x00007FF81DA90000 3.7.7150.1013        _decimal.pyd
0x00007FF829D10000                      _pocketfft_internal.cp37-win_amd64.pyd
0x00007FFFCD1C0000                      mtrand.cp37-win_amd64.pyd
0x00007FF81CF80000                      common.cp37-win_amd64.pyd
0x00007FF811CE0000                      bounded_integers.cp37-win_amd64.pyd
0x00007FF81FD80000                      mt19937.cp37-win_amd64.pyd
0x00007FF81CF50000                      bit_generator.cp37-win_amd64.pyd
0x00007FF833CD0000 3.7.7150.1013        _hashlib.pyd
0x00007FFFB48B0000 1.1.1.4              libcrypto-1_1.dll
0x00007FF81D9C0000                      philox.cp37-win_amd64.pyd
0x00007FF81CEE0000                      pcg64.cp37-win_amd64.pyd
0x00007FF81CE90000                      sfc64.cp37-win_amd64.pyd
0x00007FFFCCE90000                      generator.cp37-win_amd64.pyd
0x00007FFFB44B0000                      etree.cp37-win_amd64.pyd
0x00007FF81B2F0000                      _elementpath.cp37-win_amd64.pyd
0x00007FF81A1F0000 3.7.7150.1013        _socket.pyd
0x00007FF830590000 3.7.7150.1013        select.pyd
0x00007FF81A100000 3.7.7150.1013        _ssl.pyd
0x00007FFFC2410000 1.1.1.4              libssl-1_1.dll
0x00007FF82D850000 3.7.7150.1013        _queue.pyd
0x00007FF83DE60000 10.0.19041.546       mswsock.dll
0x00007FFFC1EB0000 3.7.7150.1013        unicodedata.pyd
0x00007FFFF5A50000                      sketchup.cp37-win_amd64.pyd
0x00007FFFB3BD0000 20.1.229.0           SketchUpAPI.dll
0x00007FFFCCE10000 20.1.229.63          SketchUpCommonPreferences.dll
0x00007FF83DB20000 10.0.19041.746       DNSAPI.dll
0x00007FF83DAE0000 10.0.19041.546       IPHLPAPI.DLL
0x00007FF8402F0000 10.0.19041.610       NSI.dll
0x00007FF834EA0000 10.0.19041.844       fwpuclnt.dll
0x00007FF834E10000 10.0.19041.546       rasadhlp.dll
0x00007FFFB2C60000                      pyluxcore.pyd
0x00007FF812BA0000 14.26.28720.3        VCOMP140.DLL
0x00007FFFAD440000                      OpenImageIO_LuxCore.dll
0x00007FFFB01A0000 1.2.1.0              OpenImageDenoise.dll
0x00007FFFAE0B0000 3.8.0.0              embree3.dll
0x00007FFFC0C20000 2.2.8.0              OpenCL.dll
0x00007FF82BF60000 27.21.14.6231        nvcuda.dll
0x00007FF8139E0000 27.21.14.6231        nvcuda64.dll
0x00007FFFAC4B0000 6.14.11.9000         nvrtc64_101_0.dll
0x00007FF831D20000 27.21.14.6231        nvapi64.dll
0x00007FFF9F620000 7.3.0.0              nvoptix.dll
0x00007FFFAB2B0000 27.21.14.6231        nvopencl64.dll
0x00007FF81DF80000 10.0.19041.844       drvstore.dll
0x00007FFF9BA70000 27.21.14.6231        nvrtum64.dll
0x00007FFFCCA60000 8.17.14.6231         nvml.dll
0x00007FFFAAEC0000 8.17.14.6231         nvml.dll
0x00007FFFA97A0000 27.21.14.6231        nvptxJitCompiler64.dll
# Python backtrace
You can also attach the log as a text file, it seems too long for a post.
mroy
Post by mroy »
Dade wrote: Wed Apr 14, 2021 9:15 pm
mroy wrote: Wed Apr 14, 2021 6:30 pm nvrtc: error: failed to open libnvrtc-builtins.so.
Make sure that libnvrtc-builtins.so is installed correctly.
The problem is here. Look for your libnvrtc-builtins.so inside "/home/XXX/.config/blender/2.92/scripts/addons/BlendLuxCore/bin" directory, check if the file is there and it has the "x" bit set (the execution bit).
I doubt that this is related to hilth's problem because he is working on Windows while your problem is Linux related.
ls -l ~/.config/blender/2.92/scripts/addons/BlendLuxCore/bin
total 224480
-rw-r--r-- 1 mroy  mroy         0 Apr  9 10:58 __init__.py
drwxr-xr-x 2 mroy  mroy        72 Apr 10 10:02 __pycache__
-rw-r--r-- 1 mroy  mroy      2873 Apr  9 10:58 get_binaries.py
-rwxr-xr-x 1 mroy  mroy  48414768 Apr  9 10:58 libOpenImageDenoise.so.0
-rwxr-xr-x 1 mroy  mroy  47079560 Apr  9 10:58 libembree3.so.3
-rwxr-xr-x 1 mroy  mroy   5457072 Apr  9 10:58 libnvrtc-builtins.so
-rwxr-xr-x 1 mroy  mroy   5457072 Apr  9 10:58 libnvrtc-builtins.so.11.0
-rwxr-xr-x 1 mroy  mroy   5457072 Apr  9 10:58 libnvrtc-builtins.so.11.0.194
-rwxr-xr-x 1 mroy  mroy  22293896 Apr  9 10:58 libnvrtc.so
-rwxr-xr-x 1 mroy  mroy  22293896 Apr  9 10:58 libnvrtc.so.11.0
-rwxr-xr-x 1 mroy  mroy  22293896 Apr  9 10:58 libnvrtc.so.11.0.194
-rwxr-xr-x 1 mroy  mroy   2209272 Apr  9 10:58 libtbb.so.2
-rwxr-xr-x 1 mroy  mroy    790496 Apr  9 10:58 libtbbmalloc.so.2
-rwxr-xr-x 1 mroy  mroy    148408 Apr  9 10:58 oidnDenoise
-rwxr-xr-x 1 mroy  mroy  47877720 Apr  9 10:58 pyluxcore.so
-rw-r--r-- 1 mroy  mroy     58825 Apr  9 10:58 pyluxcoretools.zip
-rw-r--r-- 1 mroy  mroy       675 Apr  9 10:58 readme.md
hilth
Post by hilth »
B.Y.O.B. wrote: Thu Apr 15, 2021 6:36 pm You can also attach the log as a text file, it seems too long for a post.
Sorry, I'll do that next time. :\
mroy wrote: Thu Apr 15, 2021 6:49 pm
total 224480
Try to do a:
ldd libnvrtc.so
