Smoke shadow is fake
potcode
Post by potcode »
Hi dev, I really like the LuxCore, cause it renders more realistic than Cycles IMO.
But it fails to render the Volume correctly, like someone posted before, it will intersect with the other objects and clip their shape.
And it fails to render the shadow of the smoke domain either, as you can see from the attachment, the shadow is cubic rather than the correct vapor shadow.
Can anyone help me? Thanks.
DionXein
Re: Smoke shadow is fake
Post by DionXein »
potcode wrote: Wed Dec 02, 2020 8:37 am And it fails to render the shadow of the smoke domain either, as you can see from the attachment, the shadow is cubic rather than the correct vapor shadow.
Shadow color controls through material output node. Dark glass - rise light bounce.
And I notice - for correct shape of volume -rise mesh density, so volume will have more information (smooth shading didn't give any effect for volume calculation).
potcode
Post by potcode »
DionXein wrote: Wed Dec 02, 2020 1:46 pm
Thank you for your reply!
For the dark glass, it always rendered dark and I don't know why even if I have set the bounce value to 20 (BiDir + Metropolis). Maybe it's because of the HDRI.
Anyway, there is an option in material output called Shadow Catcher if it's what you mentioned before, but it's unusable in the BiDir engine.
The mesh density? Do I have to subdivide the smoke domain object to get the correct render of the shadow? Sorry for so many questions, as I'm relatively new to the LuxCore, so just be able to get it working and still can't get the big picture of the engine.
DionXein
Post by DionXein »
potcode wrote: Wed Dec 02, 2020 3:19 pm For the dark glass, it always rendered dark and I don't know why even if I have set the bounce value to 20 (BiDir + Metropolis). Maybe it's because of the HDRI.
Not shadow catcher but shadow color. Yes, here it is optional.
More smooth geometry - more smooth shadows and caustics.
potcode
Post by potcode »
DionXein wrote: Thu Dec 03, 2020 3:37 am
So it's setting the shadow color, well...seems not dealing with the shadow shape?
I'm struggling to get the steam shadow references in the real world, but yeah..., it turns out that all I can get is the steam of the Valve.
I had another render using a brighter HDRI, the result looks cleaner, but it still has a black rim.
DionXein
Post by DionXein »
potcode wrote: Thu Dec 03, 2020 7:27 am I had another render using a brighter HDRI, the result looks cleaner, but it still has a black rim.
But usually there are always this black rim. Sometimes brighter, sometimes darker
potcode
Post by potcode »
DionXein wrote: Thu Dec 03, 2020 1:40 pm But usually there are always this black rim. Sometimes brighter, sometimes darker
Wow, thanks! Sometimes I feel dumb and fail to grasp the details from reality.
