Unable to Render on a MAC
				JacquesKCT
Attempting to Render gives the following error codes. Please help.
				JacquesKCT
Re: Unable to Render on a MAC
Your vague reply I think points to testing Luxmark. I did this and there wasn't an issue running the benchmarks (all combinations). I then retried running Blender 2.83.6 and rendering out a still using LuxCore and the attached errors were reported. I think the OpenCL is fine because the LuxMark tests were run without a problem, so is the problem then with the Mac OSX release of LuxCoreRender?
Same question of other thread: what LuxCore version are you using ?
Does it happen with an automatic build of the under development v2.5 (viewtopic.php?f=9&t=736) ?
				JacquesKCT
Have Tried both the 2.4 version as offered for download on the LuxCore website and 2.5 builds.
The initial problem was with the published 2.4 version.
So I tried the experimental 2.5 build but it won't / can't run because the developer hasn't signed the pyluxcore file so MacOS x sees it as malicious.
				JacquesKCT
So the Mac version is broken?
I have no idea, I don't have a Mac but v2.4 is working for other people so I assume it is a problem with your installation.
