Ceramic / teeth material
MetinSeven
Post by MetinSeven »
What would be the most sensible / correct way to create a ceramic / teeth material in LuxCoreRender?
Right now I'm doing it with the node setup below. I can imagine adding a homogeneous volume would add the SSS that is present in teeth.
Re: Ceramic / teeth material
My two cents on this :
Blendfile :
The Teeth.blend
(839.43 KiB) Downloaded 206 times
MetinSeven
Nice, thanks! So I was moving in the right direction with my material. 🙂👍
MetinSeven wrote: Thu Aug 06, 2020 7:08 am Nice, thanks! So I was moving in the right direction with my material. 🙂👍
Yes ;)
