The preview render does work. However every time I try to do a full render, the program simply stops working at compiling OpenCL kernels. And no, the drivers are OK. I cannot find anything from anywhere that could help me solve this.
i7 4770k
vega 64
Picture of the problem attached.
Luxcore crashes on compiling OpenCL kernels
Re: Luxcore crashes on compiling OpenCL kernels
Which versions are you using (Blender, LuxCore, OS...) & what does the console show? (Menu Window > Show System Console)
If it also writes something like
then just wait until it does its job.
Would also help, if you provided the scene in question.
[LuxRays][76.297] [PathOCL kernel] Compiling kernelsWould also help, if you provided the scene in question.
matthewv1998
if you are using luxcore 2.4....do you happen to have any normal maps in your scene?
