It is not supported by my CPU:
[SOVED] OIDN issues - CPU doesn't supported SSE4.1 instruction set
- Odilkhan Yakubov
Re: OIDN issues
@juangea, you was right!
Re: [SOVED] OIDN issues - CPU doesn't supported SSE4.1 instruction set
I was suspecting that, what Mathieu said was not making much sense to me, because OIDN says it requires SSE 4.1, even if you compile with SSE2 suppport, if it uses something from the SSE4.1 instruction set is not possible to make it compatible.
Mystery solved!
Mystery solved!
