I am trying out Luxcore, have a scene setup from cycles. Have holdouts setup for different parts in my scene for render layers but Luxcore ignores these settings. Does Luxcore have something I need to enable for these to work or is it an entirely different workflow
Thanks,
Craig
						holdouts in blender 2.80
Re: holdouts in blender 2.80
The conversion of Cycles to LuxCore materials is a best attempt, and doesn't support all features.
You won't really get the best out of LuxCore if you just translate the Cycles nodes, some of the materials work a lot better from scratch. I don't think LuxCore has a holdout material
LuxCore has a general transparency (or was called opacity in Blender ?) plug available in all materials. Isn't what you are looking for ?
LuxCore has no equivalent to the Cycles holdout material at the moment.
However, you can work around this, for example by masking in the compositor using the material ID.
The holdout shader sets alpha=0 on its surface: https://docs.blender.org/manual/en/late ... ldout.htmlDade wrote: Sat Nov 23, 2019 10:22 am LuxCore has a general transparency (or was called opacity in Blender ?) plug available in all materials. Isn't what you are looking for ?
