Other scenes run well on the same buld, downloaded and installed today [(1) luxcorerender-latest-win64-opencl, (2) BlendLuxCore-master].
The scene attached runs well on CPU BiDir and CPU Path but as written not on GPU Path (openCL).
In the code part below are the logs of the two successful render starts (CPU BiDir Metropolis, CPU Path Sobol).
Anay ideas what it is wrong with this scene.
As one can see, after dowload and opening with blender, the scene is, besides the emitting object, as simple as it can be.
Read prefs: C:\Users\Michael\AppData\Roaming\Blender Foundation\Blender\2.79\config\userpref.blend
found bundled python: C:\Program Files\Blender Foundation\Blender\2.79\python
pyluxcore version: 2.2alpha1
cmolcore imported with success! v1.01
Updating OpenCL device list
Read blend: T:\_Render Art\_Scenes\Blender Crash on GPU_.blend
[Engine/Final] Rendering layer "RenderLayer"
[Exporter] Creating session
[SDL][202.484] Camera type: orthographic
[SDL][202.484] Camera position: Point[0.195649, -18.1203, 0.167139]
[SDL][202.484] Camera target: Point[0.195649, -17.1203, 0.167139]
[SDL][202.484] Camera clipping plane disabled
[SDL][202.484] Texture definition: 1770116184920IOR
[SDL][202.484] Volume definition: 1770095911064
[SDL][202.484] Volume definition: 1770095913848
[SDL][202.484] Material definition: Surface_Matte__Default__Emission_1769730622776
[SDL][202.484] Material definition: Surface_Matte__Default__Dense_1770115158104
[SDL][202.484] Material definition: Surface_Glossy__Dense__Orange_1770110791304
[SDL][202.484] The Mesh_Circle_1770112336952000 object is a light sources with 32 triangles
[SDL][202.484] Scene objects count: 7
[SDL][202.484] Light definition: Lamp_Point_1770107988168
[LuxCore][202.484] Configuration:
[LuxCore][202.500] light.maxdepth = 10
[LuxCore][202.516] path.maxdepth = 10
[LuxCore][202.516] sampler.sobol.adaptive.strength = 0.94999998807907104
[LuxCore][202.516] sampler.random.adaptive.strength = 0.94999998807907104
[LuxCore][202.516] sampler.metropolis.largesteprate = 0.40000000000000002
[LuxCore][202.516] sampler.metropolis.maxconsecutivereject = 512
[LuxCore][202.516] sampler.metropolis.imagemutationrate = 0.10000000000000001
[LuxCore][202.516] renderengine.type = "BIDIRCPU"
[LuxCore][202.516] film.filter.type = "NONE"
[LuxCore][202.516] film.width = 1080
[LuxCore][202.516] scene.epsilon.min = 9.9999997473787516e-06
[LuxCore][202.516] sampler.type = "METROPOLIS"
[LuxCore][202.516] lightstrategy.type = "LOG_POWER"
[LuxCore][202.516] film.filter.width = 1.5
[LuxCore][202.516] scene.epsilon.max = 0.10000000149011612
[LuxCore][202.516] film.height = 1080
[LuxCore][202.516] film.opencl.enable = 1
[LuxCore][202.516] film.opencl.device = 0
[LuxCore][202.516] path.forceblackbackground.enable = 0
[LuxCore][202.516] renderengine.seed = 1
[LuxCore][202.516] film.outputs.0.type = "RGB_IMAGEPIPELINE"
[LuxCore][202.516] film.outputs.0.index = 0
[LuxCore][202.516] film.outputs.0.filename = "RGB_IMAGEPIPELINE_0.png"
[LuxCore][202.531] film.imagepipelines.0.0.type = "NOP"
[LuxCore][202.531] film.imagepipelines.0.1.type = "TONEMAP_AUTOLINEAR"
[LuxCore][202.531] film.imagepipelines.0.2.type = "TONEMAP_LINEAR"
[LuxCore][202.531] film.imagepipelines.0.2.scale = 0.5
[LuxCore][202.531] film.imagepipelines.0.radiancescales.0.enabled = 1
[LuxCore][202.531] film.imagepipelines.0.radiancescales.0.globalscale = 1
[LuxCore][202.531] film.imagepipelines.0.radiancescales.0.rgbscale = 1 1 1
[LuxCore][202.531] batch.halttime = 0
[LuxCore][202.531] batch.haltthreshold = 0.0001
[LuxCore][202.531] batch.haltspp = 750
[LuxCore][202.531] batch.haltthreshold.stoprendering.enable = 0
[LuxCore][202.531] File Name Resolver Configuration:
Export took 0.1 s
[LuxCore][202.531] Film resolution: 1080x1080
[SDL][202.531] Film output definition: RGB_IMAGEPIPELINE [image.png]
[SDL][202.531] Image pipeline: film.imagepipelines.0
[SDL][202.531] Image pipeline step 0: NOP
[SDL][202.531] Image pipeline step 1: TONEMAP_AUTOLINEAR
[SDL][202.531] Image pipeline step 2: TONEMAP_LINEAR
[SDL][202.531] Film output definition: RGB_IMAGEPIPELINE [RGB_IMAGEPIPELINE_0.png]
[LuxRays][202.531] OpenCL Platform 0: Advanced Micro Devices, Inc.
[LuxRays][202.531] Device 0 name: NativeThread
[LuxRays][202.531] Device 0 type: NATIVE_THREAD
[LuxRays][202.531] Device 0 compute units: 1
[LuxRays][202.531] Device 0 preferred float vector width: 4
[LuxRays][202.531] Device 0 max allocable memory: 0MBytes
[LuxRays][202.547] Device 0 max allocable memory block size: 0MBytes
[LuxRays][202.547] Device 1 name: Hawaii
[LuxRays][202.547] Device 1 type: OPENCL_GPU
[LuxRays][202.547] Device 1 compute units: 40
[LuxRays][202.547] Device 1 preferred float vector width: 1
[LuxRays][202.547] Device 1 max allocable memory: 8192MBytes
[LuxRays][202.547] Device 1 max allocable memory block size: 4048MBytes
[LuxRays][202.547] Device 2 name: Hawaii
[LuxRays][202.547] Device 2 type: OPENCL_GPU
[LuxRays][202.547] Device 2 compute units: 40
[LuxRays][202.547] Device 2 preferred float vector width: 1
[LuxRays][202.547] Device 2 max allocable memory: 4096MBytes
[LuxRays][202.547] Device 2 max allocable memory block size: 3264MBytes
[LuxRays][202.547] Creating 8 intersection device(s)
[LuxRays][202.547] Allocating intersection device 0: NativeThread (Type = NATIVE_THREAD)
[LuxRays][202.547] Allocating intersection device 1: NativeThread (Type = NATIVE_THREAD)
[LuxRays][202.547] Allocating intersection device 2: NativeThread (Type = NATIVE_THREAD)
[LuxRays][202.547] Allocating intersection device 3: NativeThread (Type = NATIVE_THREAD)
[LuxRays][202.547] Allocating intersection device 4: NativeThread (Type = NATIVE_THREAD)
[LuxRays][202.547] Allocating intersection device 5: NativeThread (Type = NATIVE_THREAD)
[LuxRays][202.547] Allocating intersection device 6: NativeThread (Type = NATIVE_THREAD)
[LuxRays][202.547] Allocating intersection device 7: NativeThread (Type = NATIVE_THREAD)
[LuxCore][202.547] Configuring 8 CPU render threads
[LuxRays][202.547] Preprocessing DataSet
[LuxRays][202.547] Total vertex count: 2202
[LuxRays][202.547] Total triangle count: 4060
[LuxRays][202.547] Preprocessing DataSet done
[LuxRays][202.547] Adding DataSet accelerator: EMBREE
[LuxRays][202.563] EmbreeAccel build time: 15ms
[LuxCore][202.594] Film OpenCL image pipeline
[LuxCore][202.594] Film OpenCL Device used: Hawaii Intersect
[LuxCore][202.594] Device OpenCL version: OpenCL 2.0 AMD-APP (2766.5)
[LuxRays][203.109] [Device Hawaii Intersect] IMAGEPIPELINE buffer size: 13668Kbytes
[LuxRays][203.125] [Device Hawaii Intersect] Merge buffer size: 18225Kbytes
[LuxCore][203.125] [MergeSampleBuffersOCL] Defined symbols: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL
[LuxCore][203.125] [MergeSampleBuffersOCL] Compiling kernels
[LuxCore][203.125] [MergeSampleBuffersOCL] Kernels cached
[LuxCore][203.125] [MergeSampleBuffersOCL] Compiling Film_MergeBufferInitialize Kernel
[LuxCore][203.141] [MergeSampleBuffersOCL] Compiling Film_MergeRADIANCE_PER_PIXEL_NORMALIZED Kernel
[LuxCore][203.141] [MergeSampleBuffersOCL] Compiling Film_MergeRADIANCE_PER_SCREEN_NORMALIZED Kernel
[LuxCore][203.141] [MergeSampleBuffersOCL] Compiling Film_MergeBufferFinalize Kernel
[LuxCore][203.141] [MergeSampleBuffersOCL] Kernels compilation time: 15ms
[LuxRays][203.266] [Device Hawaii Intersect] Accumulation buffer size: 106Kbytes
[LuxCore][203.266] [AutoLinearToneMap] Defined symbols: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL
[LuxCore][203.266] [AutoLinearToneMap] Compiling kernels
[LuxCore][203.266] [AutoLinearToneMap] Kernels cached
[LuxCore][203.266] [AutoLinearToneMap] Compiling OpRGBValuesReduce Kernel
[LuxCore][203.266] [AutoLinearToneMap] Compiling OpRGBValueAccumulate Kernel
[LuxCore][203.266] [AutoLinearToneMap] Compiling AutoLinearToneMap_Apply Kernel
[LuxCore][203.266] [AutoLinearToneMap] Kernels compilation time: 0ms
[LuxCore][203.266] [LinearToneMap] Defined symbols:
[LuxCore][203.266] [LinearToneMap] Compiling kernels
[LuxCore][203.266] [LinearToneMap] Kernels cached
[LuxCore][203.266] [LinearToneMap] Compiling LinearToneMap_Apply Kernel
[LuxCore][203.266] [LinearToneMap] Kernels compilation time: 0ms
Session started in 0.8 s
Recommended clamp value: 3.0348515630046258
[LuxCore][230.828] [Hawaii Intersect] Memory used for OpenCL image pipeline: 36352Kbytes
[SDL][243.375] Camera type: orthographic
[SDL][243.375] Camera position: Point[0.195649, -18.1203, 0.167139]
[SDL][243.375] Camera target: Point[0.195649, -17.1203, 0.167139]
[SDL][243.375] Camera clipping plane disabled
[SDL][243.391] Texture definition: 1770116184920IOR
[SDL][243.422] Volume definition: 1770095911064
[SDL][243.422] Volume definition: 1770095913848
[SDL][243.422] Material definition: Surface_Matte__Default__Emission_1769730622776
[SDL][243.422] Material definition: Surface_Matte__Default__Dense_1770115158104
[SDL][243.422] Material definition: Surface_Glossy__Dense__Orange_1770110791304
[SDL][243.422] The Mesh_Circle_1770112336952000 object is a light sources with 32 triangles
[SDL][243.422] Scene objects count: 7
[SDL][243.422] Light definition: Lamp_Point_1770107988168
[LuxCore][243.422] Configuration:
[LuxCore][243.422] path.pathdepth.total = 9
[LuxCore][243.422] path.pathdepth.diffuse = 7
[LuxCore][243.422] path.pathdepth.glossy = 7
[LuxCore][243.422] path.pathdepth.specular = 8
[LuxCore][243.422] sampler.sobol.adaptive.strength = 0.94999998807907104
[LuxCore][243.422] sampler.random.adaptive.strength = 0.94999998807907104
[LuxCore][243.422] sampler.metropolis.largesteprate = 0.40000000000000002
[LuxCore][243.422] sampler.metropolis.maxconsecutivereject = 512
[LuxCore][243.422] sampler.metropolis.imagemutationrate = 0.10000000000000001
[LuxCore][243.422] renderengine.type = "PATHCPU"
[LuxCore][243.422] film.filter.type = "NONE"
[LuxCore][243.422] film.width = 1080
[LuxCore][243.422] scene.epsilon.min = 9.9999997473787516e-06
[LuxCore][243.422] sampler.type = "SOBOL"
[LuxCore][243.422] lightstrategy.type = "LOG_POWER"
[LuxCore][243.422] film.filter.width = 1.5
[LuxCore][243.422] scene.epsilon.max = 0.10000000149011612
[LuxCore][243.422] film.height = 1080
[LuxCore][243.438] film.opencl.enable = 1
[LuxCore][243.438] film.opencl.device = 0
[LuxCore][243.438] path.forceblackbackground.enable = 0
[LuxCore][243.438] renderengine.seed = 1
[LuxCore][243.438] film.outputs.0.type = "RGB_IMAGEPIPELINE"
[LuxCore][243.438] film.outputs.0.index = 0
[LuxCore][243.438] film.outputs.0.filename = "RGB_IMAGEPIPELINE_0.png"
[LuxCore][243.438] film.imagepipelines.0.0.type = "NOP"
[LuxCore][243.438] film.imagepipelines.0.1.type = "TONEMAP_AUTOLINEAR"
[LuxCore][243.438] film.imagepipelines.0.2.type = "TONEMAP_LINEAR"
[LuxCore][243.438] film.imagepipelines.0.2.scale = 0.5
[LuxCore][243.438] film.imagepipelines.0.radiancescales.0.enabled = 1
[LuxCore][243.438] film.imagepipelines.0.radiancescales.0.globalscale = 1
[LuxCore][243.438] film.imagepipelines.0.radiancescales.0.rgbscale = 1 1 1
[LuxCore][243.438] batch.halttime = 0
[LuxCore][243.438] batch.haltthreshold = 0.0001
[LuxCore][243.438] batch.haltspp = 750
[LuxCore][243.438] batch.haltthreshold.stoprendering.enable = 0
[LuxCore][243.438] File Name Resolver Configuration:
Export took 0.1 s
[LuxCore][243.438] Film resolution: 1080x1080
[SDL][243.438] Film output definition: RGB_IMAGEPIPELINE [image.png]
[SDL][243.438] Image pipeline: film.imagepipelines.0
[SDL][243.438] Image pipeline step 0: NOP
[SDL][243.438] Image pipeline step 1: TONEMAP_AUTOLINEAR
[SDL][243.438] Image pipeline step 2: TONEMAP_LINEAR
[SDL][243.438] Film output definition: RGB_IMAGEPIPELINE [RGB_IMAGEPIPELINE_0.png]
[LuxRays][243.438] OpenCL Platform 0: Advanced Micro Devices, Inc.
[LuxRays][243.438] Device 0 name: NativeThread
[LuxRays][243.438] Device 0 type: NATIVE_THREAD
[LuxRays][243.438] Device 0 compute units: 1
[LuxRays][243.438] Device 0 preferred float vector width: 4
[LuxRays][243.453] Device 0 max allocable memory: 0MBytes
[LuxRays][243.453] Device 0 max allocable memory block size: 0MBytes
[LuxRays][243.453] Device 1 name: Hawaii
[LuxRays][243.453] Device 1 type: OPENCL_GPU
[LuxRays][243.453] Device 1 compute units: 40
[LuxRays][243.453] Device 1 preferred float vector width: 1
[LuxRays][243.453] Device 1 max allocable memory: 8192MBytes
[LuxRays][243.453] Device 1 max allocable memory block size: 4048MBytes
[LuxRays][243.453] Device 2 name: Hawaii
[LuxRays][243.453] Device 2 type: OPENCL_GPU
[LuxRays][243.453] Device 2 compute units: 40
[LuxRays][243.453] Device 2 preferred float vector width: 1
[LuxRays][243.453] Device 2 max allocable memory: 4096MBytes
[LuxRays][243.453] Device 2 max allocable memory block size: 3264MBytes
[LuxRays][243.453] Creating 8 intersection device(s)
[LuxRays][243.453] Allocating intersection device 0: NativeThread (Type = NATIVE_THREAD)
[LuxRays][243.453] Allocating intersection device 1: NativeThread (Type = NATIVE_THREAD)
[LuxRays][243.453] Allocating intersection device 2: NativeThread (Type = NATIVE_THREAD)
[LuxRays][243.453] Allocating intersection device 3: NativeThread (Type = NATIVE_THREAD)
[LuxRays][243.453] Allocating intersection device 4: NativeThread (Type = NATIVE_THREAD)
[LuxRays][243.453] Allocating intersection device 5: NativeThread (Type = NATIVE_THREAD)
[LuxRays][243.453] Allocating intersection device 6: NativeThread (Type = NATIVE_THREAD)
[LuxRays][243.453] Allocating intersection device 7: NativeThread (Type = NATIVE_THREAD)
[LuxCore][243.453] Configuring 8 CPU render threads
[LuxRays][243.453] Preprocessing DataSet
[LuxRays][243.453] Total vertex count: 2202
[LuxRays][243.453] Total triangle count: 4060
[LuxRays][243.453] Preprocessing DataSet done
[LuxRays][243.453] Adding DataSet accelerator: EMBREE
[LuxRays][243.469] EmbreeAccel build time: 16ms
[LuxCore][243.516] Film OpenCL image pipeline
[LuxCore][243.516] Film OpenCL Device used: Hawaii Intersect
[LuxCore][243.516] Device OpenCL version: OpenCL 2.0 AMD-APP (2766.5)
[LuxRays][243.594] [Device Hawaii Intersect] IMAGEPIPELINE buffer size: 13668Kbytes
[LuxRays][243.609] [Device Hawaii Intersect] Merge buffer size: 18225Kbytes
[LuxCore][243.609] [MergeSampleBuffersOCL] Defined symbols: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL
[LuxCore][243.609] [MergeSampleBuffersOCL] Compiling kernels
[LuxCore][243.609] [MergeSampleBuffersOCL] Kernels cached
[LuxCore][243.609] [MergeSampleBuffersOCL] Compiling Film_MergeBufferInitialize Kernel
[LuxCore][243.609] [MergeSampleBuffersOCL] Compiling Film_MergeRADIANCE_PER_PIXEL_NORMALIZED Kernel
[LuxCore][243.609] [MergeSampleBuffersOCL] Compiling Film_MergeRADIANCE_PER_SCREEN_NORMALIZED Kernel
[LuxCore][243.609] [MergeSampleBuffersOCL] Compiling Film_MergeBufferFinalize Kernel
[LuxCore][243.641] [MergeSampleBuffersOCL] Kernels compilation time: 31ms
[LuxRays][243.719] [Device Hawaii Intersect] Accumulation buffer size: 106Kbytes
[LuxCore][243.719] [AutoLinearToneMap] Defined symbols: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL
[LuxCore][243.719] [AutoLinearToneMap] Compiling kernels
[LuxCore][243.719] [AutoLinearToneMap] Kernels cached
[LuxCore][243.719] [AutoLinearToneMap] Compiling OpRGBValuesReduce Kernel
[LuxCore][243.719] [AutoLinearToneMap] Compiling OpRGBValueAccumulate Kernel
[LuxCore][243.719] [AutoLinearToneMap] Compiling AutoLinearToneMap_Apply Kernel
[LuxCore][243.719] [AutoLinearToneMap] Kernels compilation time: 0ms
[LuxCore][243.719] [LinearToneMap] Defined symbols:
[LuxCore][243.719] [LinearToneMap] Compiling kernels
[LuxCore][243.719] [LinearToneMap] Kernels cached
[LuxCore][243.719] [LinearToneMap] Compiling LinearToneMap_Apply Kernel
[LuxCore][243.719] [LinearToneMap] Kernels compilation time: 0ms
Session started in 0.3 s
Recommended clamp value: 0.684984388136739
[LuxCore][260.734] [Hawaii Intersect] Memory used for OpenCL image pipeline: 36352Kbytes
