[LuxMark] CPU not available
Entranced
Post by Entranced » Wed Mar 13, 2019 3:51 am
I can't select my CPU for OpenCL benchmarks, but GPU's run fine.
What can be the cause?
My system:
https://www.acer.com/datasheets/2014/48 ... B.004.html
Images:
https://imgur.com/a/g64uwYb
dxdiag:
https://pastebin.com/Z0yXakw7
Fox
Re: CPU not available
Post by Fox » Wed Mar 13, 2019 4:17 am
OpenCL is only for GPU.
Post by B.Y.O.B. » Wed Mar 13, 2019 9:02 am
You have to install the OpenCL drivers for your CPU.
Entranced
Re: [LuxMark] CPU not available
Post by Entranced » Fri Mar 15, 2019 11:22 pm
I have all drivers installed from AMD... what could be missing?
Post by kintuX » Sat Mar 16, 2019 1:28 pm
Check for Devices supporting OCL in your system with Geeks3D GPU Caps Viewer
Post by Dade » Sat Mar 16, 2019 3:50 pm
It is a quite old CPU, it may be not supported anymore by AMD driver due to the lack of support for some SSE instruction :idea:
alpistinho
Post by alpistinho » Sat Mar 16, 2019 3:56 pm
I think AMD dropped the OpenCl runtime for CPU's
Maybe you can install some old version, if you really want to
https://community.amd.com/thread/230440
