Solar panel
Egert_Kanep
Solar panel
Post by Egert_Kanep » Wed Aug 15, 2018 1:36 pm
Made a solar panel material in Substance designer and rendered in LuxCore.
Re: Solar panel
Post by FarbigeWelt » Thu Aug 16, 2018 6:46 am
Nice render!
How to you export to luxcore for rendering? Substance Designer does not mention it.
Egert_Kanep
Re: Solar panel
Post by Egert_Kanep » Thu Aug 16, 2018 8:18 am
I just used default metal/rough.
Discovered, that in my first render there was a problem with metal mixing so I fixed it now :D.
Re: Solar panel
Post by FarbigeWelt » Fri Aug 17, 2018 6:17 am
Looks even better.
This means, you create tiling textures first, and import them to blender adding then materials in luxcore addon?
Do you know other tiling texture creating software?
Egert_Kanep
Re: Solar panel
Post by Egert_Kanep » Fri Aug 17, 2018 8:52 am
Yes, I first create a tiling texture and then apply it to my objects. If you're interested in a simpler solution for making tiling textures check out allegorithmic's bitmap2material. But you could just do it manually in Krita.
Re: Solar panel
Post by FarbigeWelt » Fri Aug 17, 2018 10:35 am
Thank you for the hint, looks like Wrap-around mode is exactly what I was looking for.
