Chapel
Posted: Mon May 28, 2018 2:43 pm
by jarmai
Hey there people!
I haven't used luxrender for a while, and I have just realized it is evolved into LuxCore, and gave it a go in the office for a concept we are working on: a small chapel. Modelled in archicad+blender. Little bit of gimp for post (levels, curves). Hope you like it:
Re: Chapel
Posted: Mon May 28, 2018 5:20 pm
by Racleborg
Looks good, but I would like to see some shadows on to the roof from the trees, or maybe I am just viewing it incorrectly?
Re: Chapel
Posted: Mon May 28, 2018 5:47 pm
The models and vegetation look good and the interior lighting is also ok, but the overall light is very flat.
You could try to use an HDRI and/or a sun lamp for more interesting light and shadows.
Lighting is also more interesting in the morning/evening (could work well with the interior lighting, creating a contrast between blueish dark outdoor light and warm orange interior lights).
Inspiration:
https://i.pinimg.com/originals/9b/e1/b3 ... a0cbd2.jpg
https://i.pinimg.com/736x/8f/dd/69/8fdd ... houses.jpg
https://rbblog-wpengine.netdna-ssl.com/ ... Render.jpg
https://i.pinimg.com/564x/27/4a/9f/274a ... es-nap.jpg
The grass is another thing that could be improved (more "randomness", add some taller grasses and maybe some flowers).
Re: Chapel
Posted: Mon Jun 04, 2018 7:47 am
by jarmai
Hi!
Thanks for the comments! You are right about the grass and the lighting also, next time I'll try to pay attention to those.
Somehow I couldn't get a hair particle system to render and had to use a not so proper grass patch I've quickly downloaded, as children of the particle system.
For lighting I've used a hdri which I use usually in vray also, the reason of the flatness is maybe the postproduction where i turned up dark areas in gimp, because the intereior was too dark.
I forgot to post this another view last time, now here it is:
