Best Friends Forever
Cartoon-style 3D illustration
Created using a combination of polygon subdivision modeling and Sculpt Mode
Rendered using LuxCoreRender
Concept: Michael Hacker
Hope you like it!
metinseven.nl
- MetinSeven
- Contact:
Re: Best Friends Forever
Another wonderfull illustration.Thanks for this fresh creative art air. lovely
btw look like you struggle to get rid of fireflies in glass object. Do you try the shadow color trick ?
- MetinSeven
- Contact:
Many thanks, much appreciated!
I've tried the shadow trick, but it turned the glass into more of an architectural glass type, without the nice contrast in the refractions.
I could have used denoising, but that smooths out too much detail to my liking.
In the end I actually like a bit of noise. It works like a slight grain, and avoids the image getting too smooth.
As far as I remember, it is the first time I see LuxCore (or even the old Lux) used for this kind of stylized/cartoon rendering style. Who said it wasn't possible ? It looks damn good
This a quite typical field of application for Cycles but I would say that LuxCore adds a little photorealism twist.
- MetinSeven
- Contact:
Thank you David, much appreciated!
LuxCoreRender is a joy to work with because everything, including the lighting, behaves exactly as you would expect in the real world. A back light really casts that broad, bright rim it would cause in real life. I love that. Compared to LuxCoreRender, Cycles suddenly feels like a semi-realistic renderer, floating somewhere between Eevee and Lux.
In other words: I won't be using Cycles anymore.
