joyasrohrbach
Post
by joyasrohrbach » Fri Jul 24, 2020 10:31 pm
Designed for an advanced jewelry tutorial with BLENDER 2.9 - rendered with LUXCORE 2.4
Post effects painted in Painter. Scene has been mostly sculpted.
NVIDIA Cuda usage has been notably improved in 2.4
4K Image
sarmath
Post
by sarmath » Mon Jul 27, 2020 12:07 pm
Beautiful
Windows 10 Pro Ryzen 9 3900x 2xGTX 1070ti 32 GB RAM
Post
by Sharlybg » Mon Jul 27, 2020 12:14 pm
Really beautifull and complexe shape
. I think it deserve a bit longer render time the are part made too smooth by the denoiser(leaves area for example). As it is jewelry sharper reflection are needed.
joyasrohrbach
Post
by joyasrohrbach » Fri Jul 31, 2020 9:49 pm
Hi, thanks for your great comments.
That render got to 1200 samples, it is much the depth of field for the marco view making bluriness and not the denoising. The jewel is sharp, metal has roughness and bumps to make it artistically more interesting. This scene got selected in Blendernation weekly selection. I made a new version with smoke and particules rendered directly with LuxCoreRender 2.4 - I was very happy to use volumetrics and particules with Luxcore. Every particle became a light source thanks to the emision, and that gave the final composition more colors and made the scene really attractive.
You can check variants and the thread at
https://blenderartists.org/t/ring-on-a- ... es/1243187
Post
by Sharlybg » Sat Aug 01, 2020 7:46 am
joyasrohrbach wrote: ↑Fri Jul 31, 2020 9:49 pm
You rock
It should be in the gallery
Theo_Gottwald
Post
by Theo_Gottwald » Sat Aug 01, 2020 9:33 am
Amazing realistic. The coloured smoke is a interesting highligt.
At the top of the Gem i would had expected a small reflection of something not just a white vertex.
joyasrohrbach
Post
by joyasrohrbach » Tue Aug 04, 2020 12:19 am
Theo_Gottwald wrote: ↑Sat Aug 01, 2020 9:33 am
Thank you for your very nice comment. Yes, at the top... You can see the last update at
https://blenderartists.org/t/ring-on-a- ... es/1243187 - The top is still almost totally white but I did add a small color ramp from the left side.
Theo_Gottwald
Post
by Theo_Gottwald » Tue Aug 04, 2020 6:34 am
Yes, that was just the missing dots ... now looks perfect for what it should be.
