Circumhorizontal arc
wasd
Post by wasd » Fri Mar 13, 2020 6:08 pm
cza.zip
(104.01 KiB) Downloaded 10 times
CPU Bidir (sometimes GPU Path) + Metropolis | Log Power | Core i5-4570
Racleborg
Re: Circumzenithal arc
Post by Racleborg » Fri Mar 13, 2020 7:32 pm
Cool! :)
Post by CodeHD » Fri Mar 13, 2020 10:19 pm
I was going to say this atmosphere simulation topic is getting abit out of hand, but this seems to be quite a different setup :D
Looks odd with the offset water to the glass. Was this effect intended or by accident?
wasd
Post by wasd » Sat Mar 14, 2020 5:58 am
No, it wasn't intended. That's what happen when some genius in blender dev decide that it's good idea to select and move with same mouse button. In a piece of software where you can't even group objects.
Ok, I moved water back in place and arc disappeared :) It was glass out of place, so I moved them both closer to wall and arc reappeared.
wasd
Post by wasd » Sat Mar 14, 2020 5:18 pm
Also, it's not circumzenithal arc, it's circumhorizontal.
Circumzenithal would be on the floor if glass lighted from it's side.
