A quickly scene I made just to see what Luxcore was already capable of in 2.80... Seems to be pretty stable
Found a bug when used Glare node on compositor... An emission mesh kind of exploded (see example below)
What I changed from the default settings:
Halt condition: 8min
Light trace
DLSC
GI Cache
Env. light cache
Camera: Linear, Gain 1, auto brightness disabled
Rendered using Ryzen 2600x
(OpenCL seems to not be working right now, right? When activated render got stuck)
Bedroom test scene - 2.80
Re: Bedroom test scene - 2.80
Nice work!
Doesn't sound like a bug to me, you probably just have to use a different threshold in the glare node?heverton wrote: Sun Aug 11, 2019 8:46 pm Found a bug when used Glare node on compositor... An emission mesh kind of exploded (see example below)
Which GPU do you have? Try updating to the latest drivers.heverton wrote: Sun Aug 11, 2019 8:46 pm (OpenCL seems to not be working right now, right? When activated render got stuck)
- FarbigeWelt
- Contact:
Tried 2.8 two weeks ago rendered quite complex scenes openCL.heverton wrote: Sun Aug 11, 2019 8:46 pm A quickly scene I made just to see what Luxcore was already capable of in 2.80... Seems to be pretty stable
Does Luxmark 3.1 run openCL on your system?
