It is included in automatic builds (however, this feature has not yet been exposed in BlendLuxCore so it can not yet be used with some hand editing of the scene): viewtopic.php?f=9&t=736
LuxCore Vector Displacements
Re: LuxCore Vector Displacements
I think it only makes sense to add this scene to the testscene repo once the BlendLuxCore displacement support is implemented.
In the meantime, I was wondering what the license of this scene is? I can only find the youtube description as source, but was that the first time it was uploaded, and under which licensing?
I could have a look at this in BlendLuxCore or who is the maintainer ???
cheers u3dreal
							cheers u3dreal
portfolio http://q3de.com/
Sure, contributions are welcome.u3dreal wrote: Thu Dec 05, 2019 6:15 pm I could have a look at this in BlendLuxCore or who is the maintainer ???
As a proof of concept I have started something here a while ago: https://github.com/LuxCoreRender/BlendL ... he.py#L157
It worked in final render, but I have not investigated yet how best to support viewport updates.
I am the main author of BlendLuxCore, if you have any questions, feel free to ask me.
To discuss this, it's probably best if you open an issue in the repo: https://github.com/LuxCoreRender/BlendL ... issues/new
OK seems i'll have a look to see if i get the concept of the code.
I added the vector displacement node to the Blender addon, this scene can now be rendered with the attached setup.
However, there are some weird lines appearing along the model, for example on the right, not sure what that's about.
These lines are also visible in the cycles video @ 5:20 Min (https://youtu.be/iNAdi1nzOvE?t=317). It seems to be releated with the uv map.B.Y.O.B. wrote: Tue Dec 17, 2019 2:10 pm I added the vector displacement node to the Blender addon, this scene can now be rendered with the attached setup.
Maybe the subdiv shape in LuxCore is not handling the UVs properly?
Nice !
In Blender 2.81 they improved Cycles behavior:
https://wiki.blender.org/wiki/Reference ... .81/Cycles
Adaptive Subdivision
Cycles adaptive subdivision now stitches faces to avoid cracks between edges, that may be caused by displacement or different materials.
