Laser, Prism and Mirror Fun
Just testing Bidir about 10000 samples and 3h render on i7 5820k...
- prism2.blend
- scene file
- (1.23 MiB) Downloaded 362 times
Re: Laser, Prism and Mirror Fun
Thanks
Just wondering when I leave only prism to render there are 2 beams coming out from the bottom but with everything else they are invisible...is it as should be???
Yes you did it so beautifull. Congratulation
Great render!
If you only setup a world volume, then the renderer can trace the light rays correctly with participating media. I added an updated .blend file. I tuned the volume and reduced the path depth a bit to get a faster render but noise is still visible after 40k spp.
- prism3.blend
- (1.26 MiB) Downloaded 324 times
Thanks for that just amazing how easy it is with luxcore now...
Please can you render this totally noise free at 1.5 or 2k so we can post it in the Luxcore website gallery ? will be really great.
That would be a hard task in 2k if neo2068 rendered this scene to 40k and its still noisy....
I think sharlybg meant the resolution (2000x2000 or so).
Still pretty hard to do.
Maybe Dade's tips from here can help? viewtopic.php?f=2&t=94#p1434
