Testing samplers and engines
Posted: Wed Feb 06, 2019 3:12 pm
by ariellev
Hello, I was having trouble with a scene for a long time with 18 lights in arbitrary placement around a large void, a complex-shaped reflecting subject with two lights and caustics, and very high lighting contrast. I was getting very many fireflies, so I tried the bidir engine. I want to make this example to show just how big this difference is. This is a version of the scene with a lot of things scrubbed from visibility due to an error I made.
Here I have rendered with the path renderer twice, to 500 samples, on two GPUs (HD 7850 and RX 570).
With the sobol sampler, 40% adaptivity, forgot to record time but it was less than half the time of the metropolis sampler:
With the metropolis sampler, untouched sampling settings, 4 and a half minutes:
Next I have rendered once with bidir and metropolis. I have limited this render to 40 minutes as I have a very slow cpu which is slightly broken (being replaced soon), I don't want to stress it too much and cause too many wrong results, and want to upload this today. As I write this it has been going for a minute and has reached three samples per pixel.
While I'm waiting for this I might as well say, since I'm bored: I chose luxcore due to the nicer reflections than cycles and is better for local rendering on my amd hardware, and even as I'm finding it's missing things currently, I believe it is right to stick with exciting new tech before it's considered useful by the crowd so that it becomes useful to the crowd.
okay it's done rendering, got to 116 samples in 40 minutes, here it is
Something to note: in the path examples, the more samples I pumped through the more fireflies there would be, 500 is a little high
so if you're having trouble with fireflies in a scene with complex lighting, try the bidir engine
Re: Testing samplers and engines
Posted: Wed Feb 06, 2019 3:17 pm
Or just use variance clamping option and/or denoiser :idea:
Posted: Wed Feb 06, 2019 3:21 pm
by ariellev
I am using the clamping option, I adjust the value so much and try all the recommended values, it really doesn't help with this scene
