Jupiter
Jupiter
Post by B.Y.O.B. » Tue Nov 27, 2018 1:09 am
Slicing a volume with a sphere.
400 samples, 22 minutes.
scene setup
denoised with BCD
denoised with Optix
raw
Re: Jupiter
Post by B.Y.O.B. » Tue Nov 27, 2018 2:09 am
Mapping a colorramp to the density because color export is friggin' slow.
Scattering scale is probably too low.
raw
optix
Racleborg
Re: Jupiter
Post by Racleborg » Sat Dec 22, 2018 9:37 am
I'd like to learn how to create volumes like this and understand the node settings
Would it be ok for you to upload the model so that I can learn from it?
Thanks
Re: Jupiter
Post by B.Y.O.B. » Sat Dec 22, 2018 12:10 pm
Here's the file.
I baked 29 frames, which produced 7.24 GB of simulation data.
The main idea here is that I don't render the domain cube at all. Instead, I use the generated smoke data to control the interior volume of the sphere (so the outer boundary of the volume is spherical, not cubic).
jupiter_01.blend
(4.63 MiB) Downloaded 60 times
Racleborg
Re: Jupiter
Post by Racleborg » Sat Dec 22, 2018 5:21 pm
Many thanks
I like the sound of the method:
