Clouds
Clouds
Post by B.Y.O.B. » Sat Sep 29, 2018 4:24 pm
I'm currently trying to render some clouds since I stumbled upon this talk: https://youtu.be/-d8qT5-1LOI
For this I needed the remap function.
I first formed it out of nodes (the new_math_textures branch has a new "divide" texture).
But this is a) clunky to use with a lot of nodes and b) slow.
So I implemented a new "remap" texture in LuxCore. This roughly doubled my Samples/Sec.
All of this is only in the new_math_textures branch so far, I need to write the OpenCL versions before I can merge anything into the master branch.
top right: remap function made with nodes, below: the new "remap" node
Re: Clouds
Post by B.Y.O.B. » Sun Sep 30, 2018 11:04 am
My clouds don't look remotely like I want them, yet.
But here's a 12 minute render of the setup I have so far.
nodes of the scattering texture
volume settings. My stuff is not modelled to scale yet, so ignore the step size unit.
Re: Clouds
Post by B.Y.O.B. » Thu Oct 18, 2018 1:34 pm
Some new experiments with a simpler setup.
provisory
Re: Clouds
Post by provisory » Thu Oct 18, 2018 7:00 pm
Looks great!
It doesn't use hdri (only the built-in sun and sky) does it?
marcatore
Re: Clouds
Post by marcatore » Thu Oct 18, 2018 7:25 pm
Yes, it's really a good result.
Re: Clouds
Post by B.Y.O.B. » Thu Oct 18, 2018 9:29 pm
Yes, only the built-in sun and sky.
Re: Clouds
Post by FarbigeWelt » Fri Oct 19, 2018 9:35 am
This is what I call innovation.
This procedural clouds look phantastic!
Re: Clouds
Post by B.Y.O.B. » Thu Oct 25, 2018 8:54 pm
I just wanted to do some ground fog, but then I added in a few mountains and two cloud layers on top.
The mountain texture obviously needs to be improved, and the ground fog is a) to dense and b) seems to show some stepping artifacts on the left (although I changed step size and max steps and it didn't help).
Render time around 2 hours with Path OpenCL on HD 7970.
raw
denoised + compositing
Re: Clouds
Post by FarbigeWelt » Fri Oct 26, 2018 3:44 pm
Astonishing!
I like the composition with the glares especially.
Re: Clouds
Post by B.Y.O.B. » Fri Oct 26, 2018 4:12 pm
Thanks.
Remind me to upload the files after the next LuxCore release is out (you need the latest binaries, otherwise they don't work).
