First render in LuxCore - interior
Posted: Fri Sep 21, 2018 8:45 am
by lemonade
I've just rendered my first image in LuxCore and I'm quite impressed with the results
I have a problem with ceiling and grain on wall shader, so I would appreciate any suggestions.
Re: First render in LuxCore - interior
Posted: Fri Sep 21, 2018 9:15 am
Really nice start
Can we see your ceilling shader node ?
what is your clamping value ?
Render setting ?
Posted: Fri Sep 21, 2018 9:52 am
by lemonade
Here are my settings (which are pretty default, except from increased adaptive strenght) and ceiling and wall shader node.
Posted: Fri Sep 21, 2018 10:10 am
Ok !
Can you try to render at a smaller resolution ( for fast preview) with Normal map disconnected and show the result ?
Posted: Fri Sep 21, 2018 10:18 am
by lemonade
I disconnected normal map, but result is the same.
Changing wall and ceiling shader to standard Matte Shader without any image maps and environment to flat white colour also didn't help...
The mesh itself wasn't modeled in Blender, it was importet from .fbx, so I'll check it out later.
Posted: Fri Sep 21, 2018 10:53 am
by marcatore
try to check for a double coplanar faces or some normals broken...
Posted: Fri Sep 21, 2018 11:13 am
switch to cpu if the problem disappears.
Posted: Fri Sep 21, 2018 12:35 pm
To solve Shading Issue either:
- Set the object Shading to Flat.
- Check Normals 'Auto Smooth' on, set prefered Angle (if grayed out, most likely since it's imported fbx, Clear Custom Split Normals Data)
- Post a file with only the corrupt object in it.
Posted: Fri Sep 21, 2018 5:41 pm
by lemonade
This helped
Thanks to everyone!
Btw, can someone tell me where do I find denoiser?
Posted: Fri Sep 21, 2018 6:35 pm
lemonade wrote: ↑Fri Sep 21, 2018 5:41 pm
Properties Editor > Render > LuxCore Denoiser (tick check box).
& UV Editor > T-panel > last tab named "LuxCore" (must be activated before rendering in Render settings)
Results can be observed under Render Layer pass DENOISED
- DN-pass.jpg (9.26 KiB) Viewed 6452 times
