High-res LEGO bricks testing
Lights_and_Shadows
Re: High-res LEGO bricks testing
Post by Lights_and_Shadows »
I'm not sure if you noticed this, but you forgot the throw in the nodes in that .zip. It's fine though, I figured it out I think :P
Voronoi F3 + Original Perlin.
Windows 7 Professional, x64
Intel Core i7 6700K, 4GHz
EVGA GeForce GT740 Superclocked, 4GB GDDR5
32GB RAM DDR4 (approx. 80GB with pagefile active)
RAID 0 configured HDD setup (2x 500GB Seagate Barracudas)
Lights_and_Shadows wrote: Fri Mar 22, 2019 4:10 am I'm not sure if you noticed this, but you forgot the throw in the nodes in that .zip. It's fine though, I figured it out I think :P
Seemed to be a little bit late..
Simple Bricks.zip
Simple Bricks
(3.86 MiB) Downloaded 279 times
MacBook Air with M1
Lights_and_Shadows
Sorry for the long wait, summer class had priority. Been using a new method of modeling the pieces with the FreeCAD program, been getting great results with a bit of cleanup in Blender.
Been doing some slight tweaks to the pointiness value on the edges, turned out to be too overbearing.
Lights_and_Shadows
Recent changes to how I was approaching the shader have warranted an update. After following Sharly's tutorial on SSS I gave the LEGO materials a rework, and I am very happy with what happened.
I set the Opacity of the material to around 0.65 for this to work the way it should, although it might be a bit too transparent. There's a bit of bleed-through on the wing that is closest to the camera.
Lights_and_Shadows
Nearing the end of my journey with making materials for the bricks, at long last :D
Here's a pretty decent-looking speckled black-silver color:
