High-res LEGO bricks testing
Lights_and_Shadows
Re: High-res LEGO bricks testing
Post by Lights_and_Shadows »
Results from test render, sorry about the slight fireflies.
Windows 7 Professional, x64
Intel Core i7 6700K, 4GHz
EVGA GeForce GT740 Superclocked, 4GB GDDR5
32GB RAM DDR4 (approx. 80GB with pagefile active)
RAID 0 configured HDD setup (2x 500GB Seagate Barracudas)
Lights_and_Shadows
Well crap. This was a nightmare to just preview lol. So many studs...
nigec
Post by nigec »
nice work :)
I tried Lego bricks in Sketchup, you need to find a way to hide/remove studs that you can't see ;)
Post by FarbigeWelt »
Lights_and_Shadows wrote: Tue Mar 19, 2019 2:03 am Results from test render, sorry about the slight fireflies.
This one looks great! Fantastic!
MacBook Air with M1
Lights_and_Shadows wrote: Wed Mar 20, 2019 10:00 pm Well crap. This was a nightmare to just preview lol. So many studs...
Here the nibbles look to much the same as you see in the spcularities.
MacBook Air with M1
Do you know this one here:
Bricker for *ego, and *ine*raft
MacBook Air with M1
Lights_and_Shadows
FarbigeWelt wrote: Thu Mar 21, 2019 1:00 pm Do you know this one here:
I have heard of that! Unfortunately I have no way to actually pay for it though :( it would be something I'd like to try.
And good point about the studs on the base piece -- what would be a good way to get uneven bumps on the model with just nodes? I got one to work in Cycles and it looks wonderful, but I can't translate it to LuxCore.
Okay, I see. Well, sometimes reinventing the wheels is much more fun than cycling...
Let me think about that bump thing and a solutuion in blendluxcore. I should be able to send you an axample in a few hours. ( I am currently on the the move without access to my host )
MacBook Air with M1
Lights_and_Shadows
Sounds good to me :)
If it helps narrow it down, I was referencing this particular article / site for most of the imperfection work on the Cycles side:
http://stefanmuller.com/exploring-lego-material-part-2/
Lights_and_Shadows wrote: Tue Mar 19, 2019 1:31 am
I have one (very slight) dilemma -- getting realistic uneven sections of the model. I'm hoping for a procedural approach, right now I have the Blender Distorted Noise node in place connected to a Bump node, but I can't really tell what it is doing. Maybe someone could point me in a better direction with it :) any help will be appreciated.
Simple Bricks.zip
Simple Bricks; procedural; low and high frequency
(3.31 MiB) Downloaded 264 times
Noise did not help much me in the past. I was not able to scale it what means noise kept very fine. Distorted noise actutally is a good try. Check it out on a white plane and use its value as input for colormix and that output use for the color or effect you like to change: opacity, bump, specularity, absorption. Look at my nodes in the example. There are two times almost the same threads. The difference is the scaling of the 3D mapping. You may call that frequency. Makes sense, doesn't it. High frequency (more repetetions, larger scale) and less coloring means dust, low frequency may be spots. You can change the procedural texture and play around. View port rendering is fast enough, maybe you have to increase its due time. Switch off OIDN. This AI is smart enough to bleach almost any dirt you intentionally added :-D If you are happy with the result of your experiments, think about to swithch on OIDN again.
MacBook Air with M1
