Pool test scene
Sprocket
Pool test scene
Post by Sprocket » Wed Aug 15, 2018 1:53 pm
Bidir 35k samples:
Path 7051k samples:
Re: Pool test scene
Post by B.Y.O.B. » Wed Aug 15, 2018 2:10 pm
Path 7051k samples
At such high sample counts it's almost useless to continue rendering because this is exceeding the limits of floating point precision.
Nice scene, I wonder why the caustics are so different.
Egert_Kanep
Re: Pool test scene
Post by Egert_Kanep » Wed Aug 15, 2018 2:35 pm
How can you render caustics with path engine?
Re: Pool test scene
Post by Dade » Wed Aug 15, 2018 3:49 pm
If the light source can be intersected by a ray (like area lights, sun or HDR), it can be done (even if most of the times will produce just a lot of fireflies if the light is not very large and easy to hit).
jgrover110
Re: Pool test scene
Post by jgrover110 » Wed Aug 15, 2018 7:44 pm
Try using the path engine with metropolis sampler. In my experience, this is the best method for rendering SDS caustics such as this.
Sprocket
Re: Pool test scene
Post by Sprocket » Wed Aug 15, 2018 11:22 pm
I was starting to think it wasn't going to get any better at about 3M.
I'll give it a go.
how it looks in old lux for comparison:
Sprocket
Re: Pool test scene
Post by Sprocket » Sat Aug 18, 2018 9:32 am
5000k Path + Metropolis.
jgrover110
Re: Pool test scene
Post by jgrover110 » Sat Aug 18, 2018 10:47 am
The absorption looks stronger in that image. Are all the values being kept the same? Also, with the old Lux image, the refraction doesn't look as strong.
Sprocket
Re: Pool test scene
Post by Sprocket » Sat Aug 18, 2018 12:38 pm
Yes they are same values, all i changed was rendering method.
The old lux scene uses a cauchy C value, the new has cauchy B. I just copied the value, but I think it should have been converted somehow.
Re: Pool test scene
Post by FarbigeWelt » Sat Aug 18, 2018 9:09 pm
:roll:
Are you sure?
Dispersion Cauchy C
wikipedia cauchy's expression material table
Any how..
I like your test pool scene. Especially the one showing caustics with path rendering.
Do you use volumes?
I got good results with the assumption: If you're medium is 2 m deep and you have an absorption of 2 medium gets the color of absorption at ground (if you look into the medium 90° from its surface).
