Direct Light Sampling Cache Test
Post by B.Y.O.B. » Thu Jul 26, 2018 7:07 pm
A quick comparison between the different light strategies at 1 Sample/Pixel.
The used strategy is noted on the bottom left in the statistics.
Note how the Rays/Sample value is especially low (good) in the DLSC image.
spots.blend
(162.58 KiB) Downloaded 49 times
Re: Direct Light Sampling Cache Test
Post by B.Y.O.B. » Thu Jul 26, 2018 7:12 pm
The noise in the areas where multiple lights "overlap" per cache entry begins to vanish after about 70 samples:
Post by FarbigeWelt » Thu Jul 26, 2018 7:57 pm
Very nice post. It is hard to wait for all the improvements.
marcatore
Post by marcatore » Fri Jul 27, 2018 6:55 am
Surely I didn't understand the Samples/sec value. I understood that higher is better meaning that when the rays calculations are easy, the CPU (or GPU) can complete more rays calculation in the same time and it can sample more.
Nice to know that it's not like this.
Post by B.Y.O.B. » Fri Jul 27, 2018 7:38 am
No, you understood it correctly. I was talking about the Rays/Sample, which is computed as (Rays/Sec) / (Samples/Sec).
This statistic was not visible until recently. It tells you how long the light paths per sample are on average.
Short light paths usually mean less noise.
marcatore
Post by marcatore » Fri Jul 27, 2018 8:59 am
Oh..sorry.. I've misread!
And I've gained a tip about scene efficency.
Thanks a lot
