Page 17 of 17
Test scences GPU Path vs CPU BiDir
Posted: Sun Apr 28, 2019 4:44 pm
CPU BiDir, Path and GPU Path
Maybe I have to check the CPU and GPU scene, because today they rendered Path differently, although all pictures
Unfortunately, latest ee4d881 crashes on my PC Windows system if Photon GI cache is enabled. This is why there is currently no GPU PGIC image.
This time, it does not matter if Sobol or Random sampler is chosen, the the software crashes rather evil with mouse freezer, screen flashes/flickers and best thing is to reboot after that kind of crash.
Build ee4d881 crashes with PGIC
[LuxRays][19.828] [Device Hawaii Intersect] BVH mesh vertices buffer size: 180Kbytes
[LuxRays][28.953] [Device Hawaii Intersect] BVH nodes buffer size: 361Kbytes
  File "C:\Users\Michael\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\__init__.py", line 85, in render_final
    final.render(self, scene)
  File "C:\Users\Michael\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\final.py", line 40, in render
    _render_layer(engine, scene, render_slot_stats)
  File "C:\Users\Michael\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\final.py", line 63, in _render_layer
    engine.session.Start()
RuntimeError: clCreateBuffer
ERROR: clCreateBuffer
Error: EXCEPTION_ACCESS_VIOLATION
Test scences GPU Path vs CPU BiDir_fix
Posted: Sun Apr 28, 2019 7:31 pm
Indeed the scenes have not been set up the same way.
After exchanging the point lights by emitting (irregular spectrum) planes (emits only in one direction), GPU Path and CPU Path look almost the same (PGIC seems not to matter here).
CPU BiDir, Path and GPU Path_fixed
As expected CPU BiDir looks different, quite interesting is that with BiDir one can see the whole cubes, i.e. the part behind the emitter gets light too, probably because of light mirroring in side the cube. I wonder if path BiDir (Eye 10, Light 10) compared to Path (Total 8, Diffuse 4, Glossy 4, Specualr 8) explains the mirrored light. However, the light from the plane must be brighter in case of BiDir what explains why the fonts are darker (tonemap linear, auto brightness).
Test scences GPU Path Sobol, horizontal patterns?
Posted: Sun Apr 28, 2019 9:42 pm
The pattern of Sobol on GPU looks unknown to me. Where do the horizontal patterns come from?
Animated GIF, click it if it does not play at the post's window.
The animation shows 25 to 2500 Samples over 25 frames.
Posted: Sun Apr 28, 2019 9:47 pm
FarbigeWelt wrote: Sun Apr 28, 2019 9:42 pm Where do the horizontal patterns come from?
I've also wondered about this, seen it a lot of times.
A Cascade of Prisms
Posted: Mon Apr 29, 2019 6:42 pm
A Cascade of Prisms
Setting: openCL, UniDir Path, with Sobol, two GPU (AMD, Hawai).
Animated GIF, from a few samples to 1000 and de-noised.
(The first few frames are prolonged as well as the last frame.)
The attachment Prism_openCL_PGIC.gif is no longer available
After 4000 samples there are small improvements in the 'rainbow' parts.
Prism_Path PGIC_OIDN
The same image on CPU with BiDir and Metropolis (about 6000 samples).
Prism_BiDir_OIDN
Prism_BiDir_OIDN
I like both versions of the scene, the BiDir looks rather static like some future monolith things hovering whereas the UniDir looks dynamic almost in a rush to jump at the viewer.
Posted: Tue Apr 30, 2019 10:59 am
The first one (PGI + OIDN) look amazing ;)
Posted: Tue Apr 30, 2019 10:31 pm
by Fox
B.Y.O.B. wrote: Sun Apr 28, 2019 9:47 pm
Sometimes when i render with luxcore external ui at 3840x2160 pix, render can be even half an hour later stripy, but at 6000x4500 pix, seems like sampling algorithm is more even (closer to like random gaussian was in LuxRender), even 1 minute later no black spots or stripes. But the color lines are new to me.
Posted: Thu May 02, 2019 9:42 am
It is the GPU rendering: each thread receive strip of pixels to render (16 pixels). This is done to reduce some inter-thread synchronization overhead (by 16 times with 16 pixels).
At the beginning of the rendering, if the samples have very long paths, it is easy to see the threads progress of the strip (there is a huge difference between 0, 1, 2, etc. samples over the same strip while it is not perceptible with 100, 101, 102, etc.).
