LEARNING
david57
LEARNING
Post by david57 » Thu Apr 26, 2018 5:27 am
Learning...
Re: LEARNING
Post by Racleborg » Thu Apr 26, 2018 6:22 am
How long was that rendered for, and which engine?
Is it your scene or a test scene as I downloaded it to try. Either way, great and thanks!
david57
Re: LEARNING
Post by david57 » Fri Apr 27, 2018 3:40 am
The scene is from wahn.
viewtopic.php?f=2&t=221
Im using the LuxCore version BlendLuxCore v2.0 rc1
I dont remember the render time. I was making adjustments to the render time while
it was rendering. Adjusted below what I had and it stopped rendering. My mistake.
david57
Re: LEARNING
Post by david57 » Fri Apr 27, 2018 3:42 am
Trying to come up with a glazing material for the pottery.
Re: LEARNING
Post by Racleborg » Fri Apr 27, 2018 6:24 am
Looks really nice!
david57
Re: LEARNING
Post by david57 » Sat Apr 28, 2018 5:38 am
Thanks.
david57
Re: LEARNING
Post by david57 » Wed May 02, 2018 4:36 am
Trying to fix the glass.
Also trying to use camera settings as done on this web page:
https://digital-photography-school.com/ ... otography/
I was having problems making those settings but i think the reason is i also have to adjust the
gain value on the HDRI. They are using a real camera and is no such thing as an HDRI in the real world.
david57
Re: LEARNING
Post by david57 » Fri May 04, 2018 3:26 am
This one took 3 hours 52 minutes to render 8000 samples.
I tried all 3 or the camera settings.
Linear, Camera Settings, Reinhard.
All look about the same. Cant see much of a difference.
The Blenderfile is here:
https://ufile.io/lvifr
Or here:
http://cpmfiles.com/45c
david57
Re: LEARNING
Post by david57 » Fri May 11, 2018 5:53 am
18000 Samples with OpenCL Path.
This just a start. Learning.
Re: LEARNING
Post by Racleborg » Fri May 11, 2018 10:30 pm
I like the lighting.
It's a very shiny floor!
