Page 2 of 5
Re: Graswald and The Grove - Creating Lux Materials
Posted: Wed Sep 02, 2020 12:32 am
by CEROE
GPU rendering in 2.5 not working with Blender 2.83.2 on my machine.
Tried system settings of CUDA, OptiX and OpenCL with different combinations of LuxCore API settings of OpenCL and CUDA. Turned off CPU rendering as well as combination. No luck.
Posted: Wed Sep 02, 2020 1:04 am
You need to update your NVIDIA drivers to 451+.
Posted: Wed Sep 02, 2020 1:09 am
by CEROE
Have version 452.06 installed. Studio version.
Posted: Wed Sep 02, 2020 2:31 am
by CEROE
Rendered again at 500 samples with Denoiser. (Adjusted values for transmissions. Had set most to .500, which dulled the translucency. This one looks livelier.)
Full render is 3480 x 2160 and took 50:36. (My estimated time was wrong previously)
This version is 50% of original in order to upload.
Posted: Wed Sep 02, 2020 11:44 am
CEROE wrote: ↑Wed Sep 02, 2020 1:09 am
How doesn't it work ? Do you get a console error ? A crash ?
Posted: Thu Sep 03, 2020 9:27 pm
by CEROE
It would stay in kernel compiling.
Posted: Fri Sep 04, 2020 6:04 am
by CEROE
Rendered twice with latest build of 2.5.
First render set system to OptiX and add on to CUDA. Rendered in 38:21
Second render set system to CUDA and add on to CUDA with OptiX unchecked. Rendered in 38.04
Posted: Fri Sep 04, 2020 11:05 am
CEROE wrote: ↑Fri Sep 04, 2020 6:04 am
You have rendered both times with CUDA+Optix, the current BlendLuxCore preference setting has no effect (
viewtopic.php?f=5&t=2283&start=50#p24699). Try to compare CUDA+Optix Vs. OpenCL.
Posted: Fri Sep 04, 2020 7:53 pm
by CEROE
Yeah, a big difference. With OpenCL it rendered in 53:03
Posted: Fri Sep 04, 2020 9:19 pm
CEROE wrote: ↑Fri Sep 04, 2020 7:53 pm
Yes, this is the type of scenes where RTX hardware can make a huge difference.
