Japan taste
Re: Japan taste
Post by Dade » Wed Mar 14, 2018 11:06 am
Sharlybg wrote:
Wed Mar 14, 2018 10:09 am
It is possible, not trough PCIe but through Ethernet. I mean, network rendering does what you are looking for, it is the old solution for CPU-only rendering: https://knowm.org/24-core-linux-cluster ... from-ikea/ (cheap case, cheap motherboard, no gpu, fastest CPU worth buying and a bit of ram)
The IKEA supercomputer was a (old) funny example of this kind of solution.
Don't really like such solution ! I always prefere to be as compact as possible this why in the past you see me working a lot on GPU.
The other option is to rent a server on Amazon EC2. It is expansive but it is an "on demand" cost (you pay only for what you use and only when you use it). A rendering like your will probably take something like 7-8 hours to be 100% noise free at very high resolution on a 72 core instance. For a cost of about 25$.
There isn't a more compact solution (i.e. zero space required).
But now i'm really impressed by Your job on the BIDIRECTIONAL engine it is amazing I love it. Now I'm searching for A Threadripper 1950X or a nice R7 1800X. The R7 1800x is almost 2X times faster than the i7 6700k it an amazing CPU.
Keep in mind that AMD is going to release a slightly improved version of Ryzen the next month. For the new Threadripper, we will unfortunately have to wait more (I will buy one when it comes out).
Re: Japan taste
Post by Dade » Mon Mar 19, 2018 9:33 pm
Th prices are going down before the lunch of new CPUs: https://www.anandtech.com/show/12539/am ... ipper-cpus
Re: Japan taste
Post by Sharlybg » Mon Mar 19, 2018 10:31 pm
And also Ryzen Gen 2700X is going replace both 1700x and 1800x at a price lower than 1700x for performance a bit better than current 1800x.
https://www.pcgamesn.com/amd-ryzen-2-27 ... benchmarks
