Page 2 of 3
Re: Kitchen + Living_
Posted: Tue Sep 24, 2019 12:10 pm
by Magog
Yes you are right.
I realize that 2.81 is still too unstable, and despite everything I am stubborn about using it.
Posted: Tue Sep 24, 2019 1:48 pm
Magog wrote: ↑Tue Sep 24, 2019 12:10 pm
Yes you are right.
We were among the firsts, if not the first to support Intel denoiser, you don't need Blender v2.81, you can use our implementation already in v2.80
Posted: Tue Sep 24, 2019 2:23 pm
by Magog
I remember that you were the first, since 2.79.
I use 2.81 because of some improvements I can't do without.
for example .. Change the view of the room with just one click!
Or have the possibility of the separate window when you have to import something or textures, without this possibly affecting the Render Preview ..
However, the problem of the unit from cm to meters also happens to me on 2.80. I do not understand.
Posted: Tue Sep 24, 2019 2:47 pm
Magog wrote: ↑Tue Sep 24, 2019 2:23 pm
Try to disable all addons (load Blender with factory settings) and see if it still happens then. If yes, you might want to report it as a bug in the Blender bugtracker.
Posted: Wed Sep 25, 2019 6:33 am
by Nikonov_94
But apart from the low frequency noise due to the denoising, it's still a great job, it looks quite good to me! Although I'd try to make it busier and less uniform (a couple more items, some element of decoration of the wall, maybe one or two small scratches on the kitchen surfaces?) to make it more lived in.
Posted: Wed Sep 25, 2019 7:20 am
by Racleborg
OIDIN is great for somethings, but try it with a repeated pattern or the CLOTH material node and it won't matter how many samples you use it will still blur the image too much IMHO.
Posted: Wed Sep 25, 2019 7:45 am
Racleborg wrote: ↑Wed Sep 25, 2019 7:20 am
That's not true, I don't know about cloth shader(it's too slow to use) but I rendered a lot of fabric type stuff and oidn worked just great. Of course if you have some faint high frequency texture you might need a LOT of samples to preserve it, but any type of realistic looking cloth has enough diversity and different levels of details that will show through noise.
Posted: Wed Sep 25, 2019 8:15 am
by Racleborg
lacilaci » Wed Sep 25, 2019 8:45 am
Racleborg wrote: ↑Wed Sep 25, 2019 8:20 am
I'll post an example later today or very soon as I've had this issue on a few occasions.
Posted: Wed Sep 25, 2019 8:21 am
by Magog
Nikonov_94 wrote: ↑Wed Sep 25, 2019 6:33 am
Tnx Nikonov.
This is a job prepared in a hurry for a presentation to a client .. 2 days to tackle the scene, shaders, lighting, framing and so on.
Unfortunately this situation happens more and more often.
I agree with you in making the scene more lived-in and the scene harmonious .. Maybe one day when they give me a few more days
I'm agree with u..
B.Y.O.B. wrote: ↑Tue Sep 24, 2019 2:47 pm
This happens only with Luxcore.
If I switch to Cycles the problem no longer appears.
Posted: Wed Sep 25, 2019 8:27 am
by Magog
At 2k samples and with Glossy dir/indir Pass connected to the denoise node.
Surely there are other problems also due to the lack of familiarity and mastery of the settings.
I started reading the posts about the LuxCache section, but there are so many pages to absorb and lots of tests to do at a time when I have absolutely no time.
