Interior & exterior gghouse
Peperepe77
Re: Interior & exterior gghouse
Post by Peperepe77 »
Very helpful tip Sharlybg, you answer to lacilaci question. I think the yellowish on my scene is nice to recreate sunset mood
Peperepe77 wrote: Sat Jun 15, 2019 2:15 pm My scene is lit with Hdri https://hdrihaven.com/hdri/?c=sunrise-s ... it_sunrise
So no sun light, only HDRI (with its embedded sun)?
No embeded sun i think. Hdri haven HDRI produce sharp shadow by its own.
Btw i don't really understand how the SIBL lighting system work. On the w3bsite it is said that it is intended to produce fast convergence fast render.
Sharlybg wrote: Sat Jun 15, 2019 6:27 pm Btw i don't really understand how the SIBL lighting system work. On the w3bsite it is said that it is intended to produce fast convergence fast render.
It a simple trick, it uses an high resolution image when it is directly visible and a low resolution image for all other rays. It usually results in a softer lighting and faster rendering without the draw back of a low resolution background.
P.S. it requires explicit support by the rendering engine.
Peperepe77
Yes BYOB only hdri, ther isn't sun lamp.
