Page 5 of 5
Re: Suggestion for luxcore material library / preset
Posted: Fri Feb 08, 2019 9:46 pm
by tayo6
B.Y.O.B. wrote: ↑Fri Feb 08, 2019 10:02 am
tayo6 wrote: ↑Fri Feb 08, 2019 7:55 am
It was a little bit hard trying to understand some of the words used
Make a list and we can explain them. Maybe put them in the wiki for others.
I'm trying to compare the names with the ones in cycles.
One thing, I'm looking for something like colour ramp in luxcore, i tried band but I don't think it is, could you tell me what luxcore's color ramp is? . Thanks
Re: First Instructions or Read the Friendly Manual
Posted: Fri Feb 08, 2019 9:55 pm
by tayo6
FarbigeWelt wrote: ↑Fri Feb 08, 2019 6:25 pm
I read them already, in fact I read from Yafarays doc and Appleseed render doc., ..i think that's all I've got to get better.
Thanks
My apologies, I was busier than expected.
And had to notice that a zipped file, with a little more than just a .blend file as a possible default scene, is more helpful as entry point for first users.
And this is why I started defining materials with volumes and short descriptions. Then I will test appending and linking materials to new .blend files.
Actually all easy to do.
But this is often not very readable without understandable naming system.
Not to worry, actually, luxcore is simpler than cycles. Taking my time to mess around has helped alot. I don't think I would be needing those tutorials. I would just post questions that are problematic. Thanks
Posted: Fri Feb 08, 2019 9:57 pm
by tayo6
Dade wrote: ↑Fri Feb 08, 2019 10:10 am
I read them already, in fact I read from Yafarays doc and Appleseed render doc. It was a little bit hard trying to understand some of the words used, but I won't stop experimenting, i think that's all I've got to get better.
The first Lux version was based on PBRT v1.0, LuxCore is the grandson of that project so, while it doesn't share anything anymore with the original code, it is still uses the same terminology and approach to problems.
PBRT book is available here for free:
http://www.pbr-book.org/
It is a book for developers but you may found the introduction of each chapters quite interesting (in general, not refereeing only to LuxCore) and useful to understand LuxCore.
Thank you, i would read it!!!
Posted: Fri Feb 08, 2019 10:05 pm
by epilectrolytics
tayo6 wrote: ↑Fri Feb 08, 2019 9:46 pm
There is no directly corresponding node, only Band I guess.
Posted: Fri Feb 08, 2019 10:53 pm
Internally, band is exactly the same as the color ramp in Cycles.
In the old LuxBlend addon they even had the same UI because it was possible there because of special cirumstances. Unfortunately it is not possible to use Blender's color ramp UI in custom nodes without resorting to horrible hacks.
Posted: Sat Feb 09, 2019 7:47 am
by tayo6
epilectrolytics wrote: ↑Fri Feb 08, 2019 10:05 pm
Oh okay, thanks. It did work in some instances but, there were moments it didn’t behave like color ramp. Any suggestions on what nodes I should connect to have something similar to color ramp?
Posted: Sat Feb 09, 2019 7:52 am
by tayo6
B.Y.O.B. wrote: ↑Fri Feb 08, 2019 10:53 pm
Okay, thanks for the explanation.
I have to go do more reading then. Although, I think i'm over stretching this page with different questions. I should open a new post for different question
