Open cl processor
Posted: Tue Oct 02, 2018 3:51 am
by Ezearebalo
Hi im searching some "new" processor. But i dont understand something. The cpu need to have open cl 2.0 capability to speed up renders ? Look the image, i7 and fx 6300 doesnt have it ? I should buy a brand new processor ? Thanks
Re: Open cl processor
Posted: Tue Oct 02, 2018 7:48 am
No. LuxCore uses native C++ code for CPU devices, OpenCL is only used for GPUs.
Also, the integrated GPUs in modern CPUs are not really capable of running LuxCore.
Posted: Fri Jan 04, 2019 6:01 pm
by LanePanet
As per my knowledge If you dump a clinfo application type of output against an Intel based OCL implementation, you'll see each core mapped to an OCL execution unit. The entire CPU will present itself as one OCL device. If you have a host thread active while kernels are active, a naive OCL runtime will gang schedule over the "Host" core.
turnkey pcb
Posted: Fri Jan 04, 2019 9:28 pm
by epilectrolytics
What about the Vega graphics in AMD Ryzen 2XXXG Processors?
Has someone tested those?
Posted: Fri Jan 04, 2019 10:38 pm
Some of the past AMD APU were working fine but you have to check case by case to be sure.
