Hi everyone im new with luxcore, i used to work with cycles but im sick of the noise. I never could get a sharp image ,some like Pixar or Dreamworks , i see some clean renders with luxcore and i made some nice renders, but i don't full understand all the features of the render engine. I see very poor information in the wiki and only four nice tutorials. There is a full tutorial ? Something with a indoor and a outdoor scene and a full explanation of the materials ? And a nice tutorial for the network render will be great. And a tutorial to imstall the add on in a linux server via command line.
And one thing else:
It would better an amd apu cpu or and intel i5 . It would be better a nvidia graphic card or a amd ?
I know that nvidia are better for cycles becouse the cuda cores. ?Amd work better whit open cl ?
If i get an apu a10 plus a physical r7 they will work together in a render ?
Thank you
Full tutorial...exist ?
Re: Full tutorial...exist ?
Tutorial are coming soon be patient
And the other questions ? Any idea ?
Laptop-level GPUs are often not powerful enough to run complex OpenCL code used by LuxCore. For instance, most Intel GPUs usually have a lot of problems. I would consider only discrete GPUs for rendering tasks.Ezearebalo wrote: ↑Sun Sep 30, 2018 2:39 amAnd one thing else:
AMD usually offers better price/performance ratio for OpenCL tasks but NVIDIA has the crown of top performance if you are ready to pay the price. Check http://luxmark.info/average_result/Hotel for some idea about the kind of rendering performance you can get out of GPUs.Ezearebalo wrote: ↑Sun Sep 30, 2018 2:39 amI know that nvidia are better for cycles becouse the cuda cores. ?Amd work better whit open cl ?
Any number of CPU cores and GPUs can be used by LuxCore however I don't know if the A10 GPU is good enough to run the renderings (see above).Ezearebalo wrote: ↑Sun Sep 30, 2018 2:39 amIf i get an apu a10 plus a physical r7 they will work together in a render ?
Thanks for the quick answer... i feel in home
