Cache-less solutions for animations
Posted: Sat Apr 04, 2020 7:41 am
So while caches are very useful for still images and also complex caustics simulations. They are very unwieldy for animations and not usable at all in some situations.
For this reason i had to render several quick small animations outside luxcore since instability, lack of speed and the need for careful setup was making luxcore a "problematic" choice.
So, there are few things/options for quick animations and fast preview rendering that could help a lot to make luxcore attractive to people that do a lot of anims and iterations of design.
For these purposes there are 3 main problems.
1. Direct light noise:
I recently posted here on forums a case, where env. Cache failed even on still image and produced artifacts that wouldn't go away. But aside that, this cache is not possible to use in animations where objects and/or lights are moving.
For animations and some problematic cases, portals would be much better solution.
2. GI noise:
While to superior to any other solution for GI noise, it is simply not possible to use it in animations where objects and/or lights are moving. I don't know if there is a stable and also easy to use alternative, but maybe cuda and rtx support (if they provide substantial boost) could bring luxcore performance on a comparable level to octane or e-cycles.
3. Fireflies:
Sharly posted recently an interesting comparison on how octane clamping handled not only fireflies but also overall noise very efficiently without drastically affecting overall lighting. Improved clamping could not only provide better way for luxcore to handle fireflies but also help with problem #2 a bit.
I dont think caches could be improved to a point where complex animation is a: easy to setup, b: stable enough so user has no worries that some frames will contain problems. Especially if we consider that sometimes they cannot help even in a still frame case without introducing unsolvable artifacting(env cache) and require carefull preparation of scene(photongi).
2. GI noise:
3. Fireflies:
