Page 2 of 6
Re: Little Addon for optical lenses etc.
Posted: Sun Jul 07, 2019 8:17 pm
by CodeHD
Finally had some time to continue. First addition: Material textbox as suggested by B.Y.O.B. (thanks!) together with checkboxes for smooth shading and adding an edge-split modifier.
The material must be pre-defined on some dummy object. It does not work to create a lens/mirror, add a material to it, rename the material and then enter the name in the textbox. (It only works if the material is called "Material", because Blender will automatically rename it in this case
Posted: Sat Feb 29, 2020 2:28 pm
by CodeHD
I just updated this addon to work with 2.8.
No functional changes yet, aside from expanding the readme, but I now want to continue adding more surface types or even the option of dynamic changes discussed before (If I can manage that
Posted: Sat Feb 29, 2020 6:03 pm
by wasd
That's what I've wanted to make! It's great that now I don't have to
And here's my opinion
1. Blender (2.79b) crashes when N1 goes below zero, so I'd add
min parameter equal to at least 0
num1 = IntProperty(
name="N1",
default = 32,
description="Number of radial vertices",
min = 3
2. With
unit parameter, input field would accept and display length units:
lensradius = FloatProperty(
name="Lens Radius",
default = 3.,
description="Lens outer radius",
unit = 'LENGTH'
3. With edge split object will be exported as 3 separate meshes, right? What would happen to volume?
Posted: Sat Feb 29, 2020 7:38 pm
by CodeHD
wasd wrote: ↑Sat Feb 29, 2020 6:03 pm
Good suggestions no. 1. and 2. ! I will implement that.
Regarding no. 3, so far I have not observed any problems, but that doesn't mean thee will never be any
Good reminder though, casue I wanted to try making my own edge-split for this. The blender default has the issue anyways that it stops working at shallow angles. Not sure it works though without breakign the mesh... I will try.
Edit: Nope, not quite that easy
Posted: Tue Mar 03, 2020 11:00 am
by CodeHD
I now updated the module with the suggestions from wasd. Edge-plit was replaced by split normals. Apparently edg-esplit is now deprecated anyways...
Furthermore, by request of a GitHub-issue, I already included a first version of aspheric surfaces on lenses, and mirrors can now include a central hole along the main axis.
As a funny side-effect, which I noticed while testing, you can use it to model syringe-needles
Posted: Fri Mar 06, 2020 10:57 pm
by wasd
You can also make earth (and other spherical bodies) surface with this. I also think that option to make lens horizontal (with it's axis along z axis), square-shaped and square-divided would be great addition!
With just a few clicks I made this disk section of earth, with 20 km diameter.
Look, with camera at 0.5 meter above the ground, the truck that's 6 km from camera is half beneath horizon! Other one, which is closer isn't beneath.
If it's flat plane, both trucks would be fully visible.
Posted: Fri Mar 06, 2020 11:34 pm
by CodeHD
wasd wrote: ↑Fri Mar 06, 2020 10:57 pm
The rotation (and translation) parameters are currently missing from when I switched to a custom draw method, but that is provided by Blender and will be back.
By square shaped, do you mean like, for example, a single element of such a micro-lens array?
https://www.nilt.com/wp-content/uploads ... m137tu.jpg
And square-divided? Do you mean D-shaped lenses like in this cross-section model? I already have plans to implement those.
The truck behind the horizon is a nice touch
You could take a ship instead and add it to the sunset scene from the other thread
Posted: Sat Mar 07, 2020 12:15 am
by wasd
CodeHD wrote: ↑Fri Mar 06, 2020 11:34 pm
I mean like cut-out of uv-sphere.
- square.png (10.99 KiB) Viewed 6938 times
Maybe I'll do it myself.
Posted: Sat Mar 07, 2020 8:11 pm
by CodeHD
I added a square lens. Have a look if thats what you wanted.
It is perfectly square now, so not exactly like a u,v-sphere cutout, which would deviate a lot for strongly curved surfaces.
However, the square surfaces at the moment are not perfectly defined, because I used quadrilaterals, and in this case not all vertices lie in the same plane. I will see what is the most elegant way to define surfaces elements... Shouldn't be much of a problem for most use cases though.
On a side note, I also fixed a problem with the mirrors for focal lengths < 1.
Posted: Mon Mar 09, 2020 9:06 pm
by CodeHD
I now optimized the mesh geometry of the square lens, and added a cross-section view option (D-shape) to the regular lens.
